Showing results forĀ
Search instead forĀ
Did you mean:Ā
PRI ISDN call flow problem
shabeebmohammed
Dear All,
Weird issue.. I have a E1 PRI line on a 3925 MGCP gateway to a CUCM 8.0.3.
  • Outbound calls does not reach the gateway at all.
  • Inbound calls reached the gateway, rings for max 1 sec and then disconnects.
      • the ISDN Q931 debug shows the following -
*Dec  9 09:29:58.123: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0055
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Calling Party Number i = 0x2183, '99262694'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '313'
*Dec  9 09:29:59.143: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x8055
        Cause i = 0x80A9 - Temporary failure
I escalated the issue to the Telco and still no response. Just to be on the safe side i used a spare router (cisco 2811) with the exact same config and it worked perfectly (both in and out was succesfull)
I suspect a IOS bug or something related to the IOS. I tired the following IOS and still the same issue -
c3900-universalk9-mz.SPA.150-1.M4
c3900-universalk9-mz.SPA.151-1.T
c3900-universalk9-mz.SPA.151-3.T2
c3900-universalk9-mz.SPA.151-4.M
NB: (the IOS on the 2811 router is advancedenterprise -124-22.YB8)
I also see form the above debug that the router is sending a release complete signal as soon as the inbound call comes in.
Any help will be appreciated.
Shabeeb
shabeebmohammed
i even tried the latest firmwares -
c3900-universalk9-mz.SPA.153-1.T.bin = STILL THE SAME
tried changing the slots, VWIC card, cables etc - STILL THE SAME
any suggestions.. anyone ???
Shabeeb
Probably the default security feature for toll fraud prevention that blocks the communication. See more at this URL, http://voiceonbits.com/2010/08/19/ios-15-1-toll-fraud-feature/
Please remember to rate all useful posts.
Response Signature
Please try registering a phone directly to the gateway then transfer the incoming call to him. If the call complete maybe is as Roger said cause by Toll Fraud prevention.
_____________________________
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Guys..
It was the problem with the DSPs not being detected properly by the gateway. Removed and re-insterted the PVDM, rebooted the router - All working fine now.
Thanks a ton for your suggestions.
Shabeeb
