PRI Monitoring Status
Siva chinap
Level 5
Level 5
Hi All,
Is there any command to collect the Number of Channels utilized for past a month ?
Is there any software to monitor the total number of channels used per day?
Jitender Bhandari
Hi Shiva,
See below for help, you can either use SNMP or RTMT.
https://supportforums.cisco.com/discussion/9877426/pri-monitoring-problem-snmp
http://www.netcraftsmen.com/creating-custom-alerts-in-rtmt/
(Rate if it helps)
JB
Ratheesh Kumar
Hi Siva
This might can help you out
https://supportforums.cisco.com/discussion/11427671/show-pri-average-number-concurrent-channels-used
