10-12-2012 09:03 AM - edited 03-16-2019 01:39 PM
Let me give me a a brief description of the set up
H. 323, PRI's are at both locations and an 220mb Opti-Man fiber connects the two sites. Call Manager 7.1.3 and Unity Connections 8.6.2
If the PRI at one location goes down, internal calling still works fine. I know I can make outbound calls at the downed site, but i am not sure what command needs to go on the rempote gateway to allow this.
10-12-2012 09:05 AM
You can put another route group inside your route list, for backup!
Like the example you can multiple call routing choices!
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/dialplan.html#wp1044260
Leonardo Santana
Rate this if helps!
10-12-2012 09:06 AM
can you please give me an example of what the command might look like?
10-12-2012 09:11 AM
See the example above!
10-12-2012 09:16 AM
o geeze sorry, I was viewing your previous answer in my email and the diagram wasnt showing up.
10-12-2012 09:20 AM
Ok, take a look on the CUCM SRND!
Route Patter ->> RL ->>> RG1, RG2
Inside the route group you have the devices that yoy wanna route the call!
Rate this if helps!
Leonardo Santana!
