08-19-2015 06:10 AM - edited 03-17-2019 04:02 AM
during migration of my cucm ver 11 from one UCSC-220 to another UCSC-220 i have faced this problem
does anyone see this issue ? what is the reason and solution for it if anyone know
text for the problem
" Cisco Unified Communications Manager 11.0.1.10000-10
Critical Error
The installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
"Fusr/local/cm/script/cm-dbl-install HU PostInstall 11.0.1.10000-10 11.0.1.10000-10 /usr/local/cm/ /common/ml_root_dir/cluster-192.168.178.3/node-192.168.1 78.3//component/database /common/log/install/capture.txt failed (1)
The system will now halt."
08-19-2015 07:54 AM
You would need to look at the actual logs to pinpoint the error, in the past, some issues were related to dial plans and locales, but no way to tell without the actual logs and not just the screenshot.
08-20-2015 01:57 AM
do you mean the logs appears on PCD web interface during migration ?
another erorr appeared during migrating CUC
08-20-2015 06:33 AM
No, you get the logs, as you would get them from any CUCM/CUC install.
