Walkthrough Wednesdays
135
paddingtonpd
Beginner
Prioritising PRI lines on Cisco VOIP Gateway
Hi all,
I have CUCM version 8.5  connecting to a C6500 series switch as its gateway. I have a total of 6 PRI lines in the switch with 3  PRI lines going to  PSTN  A  and the other 3 going to PSTN B.  I would like to know how to prioritise outgoing calls to prefer one PSTN provider ofer the other.
2 REPLIES 2
Abhay Singh Reyal
Enthusiast
You can use Trunk Group for that
Find the below link helpful
https://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_t1_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1500903
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Chris Deren
Hall of Fame Master
What protocol do you use to control the GW/PRIs? Is it SIP/H323 or MGCP?
If SIP/H323 use dial-peers with trunk groups, if MGCP build proper Route Groups/Route Lists pointing to appropriate PRIs in CUCM.
Content for Community-Ad
Spotlight Awards 2021
