12-03-2007 11:58 AM - edited 03-15-2019 07:34 AM
Hi! I've used "Enforce Privacy Setting on Held Calls" for privacy on hold in the services settings of CM 4.2, but can't find it anywhere in 5.1. Thoughts???
Solved! Go to Solution.
12-03-2007 12:03 PM
The feature migration on CallManager was such that CallManager 4.1 and a few new features were added in CallManager 5.x.
Since Privary on Hold is a feature which was added in CallManager 4.2, it would not be available with CM 5.1. The migration path for CallManager is, CallManager 4.2 to 6.0. Therefore, if the feature was added in CM 4.2, the same would be available in CallManager 6.0 and not 5.1
Hope this helps
12-03-2007 12:03 PM
Hope this helps
