Private Number Call Feature
mohdalhafiz85
Hi Cisco
We here are using ISDN connection which is subscribing 100 DID number. We want call to PSTN our receiver can see DID number but in the same time the receiver also see the Private Number.
I already contact our Telco that they only can choose the number from 100 to make it as private fro example did number from 1001-1080 can see the DID and 1081 - 1100 is private number.
Assume all the IP phone will configure the DID not private number which is 1001-1080. How can i configure in the CUCM to allow the caller make a call to pstn then the receiver will see it as private number?
For example Caller with DID number 1001.
Call to PSTN Mobile A - Mobile A will see the DID number
Call to PSTN Mobile B - Mobile B will see the Private number.
Jaime Valencia
Simply set that in the RP, you can set another RP and use a code so that anyone can dial and choose whether to show or hide their ANI
java
if this helps, please rate
Hi Jaime
May i know how can i have the documentation to configure that features?
In your CUCM go to the RP, then help -> for this page.
java
