Probelem With CCM Admin Updating phone Lines
abduljaleel
Hi ,
I am having problem with updating the phone lines from the ccmadmin page i get an http error .
please find the screen shots attached .. do advice asap ..
We need to update few phones asap i would really appreciate prompt help from you
Cheers
AJ
mchandak
Level 7
Level 7
If the porb occured after installing the Dev Pack for DST patch, then you are hitting into CSCsg22098. This is applicable on all Java based new generation phones
