hello
I need help
Our customer has a phone CP-9971-CL-K9 with CP-CAM-C and CP-PWR-CUBE-4.
When connected 2 x CP-CKEM-C phone reset.
What could be wrong?
Thanks for your help
Sorry for my english
Kris
Hi Kris,
a. What is the CUCM version u are using ?
b. what is the 9971 firmware?
c. Does the phone work fine when single KEM is connected ?
d. How the 9971 phone is getting power? IF it is working on 802.3AF , then u need to connect power CUBES to both KEMs.
regds,
aman
Firmware is 9.3.4.24. CUCM version is 8.6.2. I use power cube. Resets happens when BLF is configured on Phone, Phone + 1CKEM or Phone + 2CKEM.
Hi Marcin,
are u using Power cube for both CKEMs? how 9971 is geting power?
Secondly, if u do not configure BLF, does 9971 phone not reset.
regds,
aman
9971 geting power for power cube 4 (48W), when i do not configure BLF - phone works fine with CKEM and SD buttons. I can only configure max 4 BLF (on phone or CKEM), when i configure more then 4 BLF on phone or CKEM - phone starts resets and register to backup CUCM, then to SRST, then to Primmary CUCM, then to Backup ... Subscribe CCS is ok, Phone is in Default Presence Group.
Thanks for any help
Hi Marcin,
I could not find the cause /bug behind such behaviour.
If anybody has come across the issue,please advise.
regds,
aman
I don't think you could power both modules by regular PoE. Are you using external power adapters for the module?
I'm waiting for information from the client.
