ā01-20-2011 03:44 PM - edited ā03-16-2019 02:59 AM
Hello I have a problem with GW my incoming calls from PSTN have a DID 037X but I have another numbers internaly with same numbers 037XXXXX: Can I to do that DID 037[0-9] are sent to exts but calls outgoing 037XXXXX also work?
Any suggestion?
This Work
dial-peer voice 37 voip
destination-pattern 037.
translate-outgoing called 1
voice-class h323 1
session target ipv4:10.X.X.X
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate 9600
no vad
But I need use this but do not work
dial-peer voice 30 voip
destination-pattern 037.....
voice-class h323 1
codec g711ulaw
fax rate 9600
no vad
can anyone help me?
ā01-20-2011 03:54 PM
Santiago,
your problem description is not very clear.
are you sure you have 037x coming from PSTN (inbound), in which case I am assuming you are stripping down to 4 digits using a translation set "translate-outgoing called 1" as on dial-peer 37? what does this translation look like?
how many digits are youn internal extensions?
can you paste the complete configuration in.?
ā01-20-2011 04:14 PM
translate-outgoing called 8
voice-class h323 1
codec g711ulaw
fax rate 9600
ip qos dscp cs5 media
no vad
My call flow is
outgoing fails
PBX>Gateway>call 03712345 failed
incoming work ok
Mobile>PSTN>GW>DID037[0-9]>Ext IP Phone
hello Dennis, I have 037X ibound from PSTN,
controller E1 0/2/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country telmex
category 2
answer-signal group-b 1
caller-digits 4
groupa-callerid-end
description TELMEX
I have a PBX in this port 1/0, the Phone analog of PBX is necessary to call 037XXXXX but the calls to do match with DID is my problem
controller E1 1/0
framing NO-CRC4
clock source internal
ds0-group 0 timeslots 1-15,17-31 type r2-digital dtmf dnis
description enlace PBX
voice-port 0/2/0:0
cptone MX
timeouts initial 2
timeouts interdigit 2
timeouts call-disconnect 5
timeouts wait-release 5
voice-port 1/0:0
translation-rule 8
Rule 0 0370 93444 ANY network
Rule 1 0371 93409 ANY network
Rule 2 0372 93426 ANY network
Rule 3 0373 93588 ANY network
Rule 4 0374 93230 ANY network
Rule 5 0375 93242 ANY network
Rule 6 0376 93222 ANY network
Rule 7 0377 93518 ANY network
Rule 8 0378 93231 ANY network
Rule 9 0379 93203 ANY network
ā01-20-2011 04:17 PM
Hello Dennis this is my config
controller E1 0/2/0
framing NO-CRC4
cas-custom 0
country telmex
category 2
caller-digits 4
groupa-callerid-end
description TELMEX
controller E1 1/0
framing NO-CRC4
voice-port 0/2/0:0
cptone MX
timeouts initial 2
voice-port 1/0:0
translation-rule 8
voice-class h323 1
codec g711ulaw
fax rate 9600
no vad
My call flow is
outgoing fails
incoming work ok
ā01-20-2011 04:40 PM
Santiago,
so If I understand this correctly:
-you have a PBX on port 1/0, with some analog phones that need to make an external call in 037XXXXX range, and currently that does not work
a-where is you incoming pots dial-peer for all incoming calls on port 1/0?
b-where is you pots dial-peer that directs external calls to PSTN (on port 2/0)?
if you are on the gateway and do a show dialplan number 03712345 what dial-peer is being hit? Also can you do a debug voip dialpeer and make an outbound call to 03712345 from one of the analog phones on the PBX.
ā01-20-2011 05:16 PM
Hello Dennis thanks you.
My answer below
dial-peer voice 830 pots
preference 5
destination-pattern 73...
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 1/0:0
forward-digits all
no register e164
dial-peer voice 840 pots
destination-pattern 09T
port 0/2/0:0
incoming called-number .
direct-inward-dial
no register e164
if you are on the gateway and do a show dialplan number 03712345 what dial-peer is being hit? This go to dial-peer voice 37 voip
voice-class h323 1
session target ipv4:10.40.7.3
codec g711ulaw
fax rate 9600
no vad
I can get this tomorrow.
ā01-21-2011 05:09 PM
Hello Dennis I already resolve my problem I change that PBX dial 8037XXXXX and add dial-peer for that.
Best Regards
