Problem E1 Intermitten
Tommy .
Hi All ,
I have Problem with E1 in Cisco Call Manager  ,  when outgoing call using E1 in phone ,status is always busy
here is the debug q931
Jan 27 06:04:13.459: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8  callref = 0x008B
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x80, '081381XXXXX'
                Plan:Unknown, Type:Unknown
*Jan 27 06:04:13.495: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x808B
        Cause i = 0x82AC - Requested circuit/channel not available
and when I check debug q921 here is what i got :
*Jan 27 06:02:30.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:31.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:32.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:33.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:34.271: ISDN Se0/3/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=13
*Jan 27 06:02:34.271: ISDN Se0/3/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=15
*Jan 27 06:02:34.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:35.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:37.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:38.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:39.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:40.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:41.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:42.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:43.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:44.271: ISDN Se0/3/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=15
*Jan 27 06:02:44.283: ISDN Se0/3/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=13
*Jan 27 06:02:44.283: ISDN Se0/3/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=15
*Jan 27 06:02:44.287: ISDN Se0/3/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=13
*Jan 27 06:02:44.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:45.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:46.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:47.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
*Jan 27 06:02:48.311: ISDN Se0/3/0:15 Q921: User RX <- SABMEp sapi=0 tei=13
I wonder where is the problem , while my e1 status
ISDN Serial0/3/0:15 interface
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 10
    Total Allocated ISDN CCBs = 0
and E1 is up
anyone kindly help ?
26 Replies 26
Hi Tommy.
On CUCM, try to change b-channel selection to bottom-up
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Also you can adding one command since this h.323 GW
interface serial XX
isdn nego b-chan
isdn b-chan ascending
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Hi Nadeem.
From posted config I see
pri-group timeslots 1-31 service mgcp
So it seems to be MGCP controlled not H323.
Carlo
that's my bad, i thought it was h.323.
Br,
Nadeem
HI Carlo ,
In the CUCM E1 Gateway i have already config channel to bottom-up or top-down but no result ,
but when outgoing E1 never change  channel other than 1 when setting top-down , and never change channel other than 31 when i set bottom-up
i have used command
isdn service b_channel 1 state 2
to force it use another channel , but the outgoing call can not procceed , and in debug isdn q931 not showing anything.
when i change isdn service b_channel 1 state 0 , debug isdn q931 out but showing no requested channel.
best regards,
Tommy
Hi Nadeem,
I Already enable the network select
Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          E1 0/3/0        GOOD            E1
    10          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          E1 0/3/0        GOOD            E1
but still outgoing status requested circuit/channel not available
regards,
Tommy
j.huizinga
Level 6
Level 6
You get a RX "Requested circuit/channel not available" after a TX from your side.
I would contact the provider.
If the E1 is MGCP controlled you might try to enable "Inhibit restarts at PRI initialization" (unselect it)
After a reset the CM will request each channel, and the provider should aknowledge this.
I the cases I had this error, it was always a provider issue.
Bye,
Jan
Hi Tommy,
Is SLIPs and errors problem resolved?
can u run the command show isdn service on router to check the channel status?
regds,
aman
Hi aman ,
nope the slip error still same , i have replaced the E1 port to another E1 but the result still same .
show isdn service
PRI Channel Statistics:
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN Se0/3/0:15, Channel [1-31]
  Configured Isdn Interface (dsl) 1
   Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
    Channel :  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
    State   :  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
   Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
    State   :  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
regards,
Tommy
Hi Jay,
I have contact the provider , and provider have confirm they have opened the channel from their side.
I have tried "Inhibit restarts at PRI initialization" but the result is still same .
Tommy
Believe me it's a provider issue.
Provider sends a RX, 'channel not available'. Provider has to tell you why they send this message. There must be a reason for it. And again, THEY send this message! Not you!
Several years ago I had a similar issue, and customer wanted to throw out Cisco, because provider says they are not blocking channels etc, finally customer wanted to sue provider, and then provider changed some equipment and all was solved.
And 1 year ago, with another customer, same issue. Provider says, they don't block channels, I told my customer, that it is a problem with the provider, and I can do nothing, and it's up to customer and provider.
After a week or so engineer from provider comes on site, does something and viola, it works! (a year without issues now)
Good luck!
Bye,
Jan
Hi Tommy,
As suggested by Jan , can't you ask Telco to check the E1 link through BERT?
regds,
aman
