01-27-2014 01:01 AM - edited 03-16-2019 09:27 PM
Dear All,
We are having some issues on a fresh installation with a Cisco 2911 connected to a remote Call Manager in Denmark. The branch site is in Belgium, when we connect the BRI's to the interfaces we get a "multiple frame established" so all is well there.
When i start a call to the outside ( mobile number), my cell phone receives it but there is no voice, when i speak through the phone my cell phone only hears static noise and after 8 seconds the call is hang up.
I've tried playing with the codecs but no luck, we should be sending the usual G711alaw. Although when i go adjust in Call Manager and make the Gateway "Media Termination Point Required" , enable Outbound FastStart with G711alaw there is 2 way voice for about 12 seconds, after this the call is ended aswell.
With no adjustsments in call manager i get the following error code:
Cause i = 0x80AF - Resource unavailable, unspecified
With adjustments in call manager: MTP, outbound faststart, i get the following:
Cause i = 0x80A9 - Temporary failure
I've done some debugging on the gateway:
************************************Call To Mobile Phone, call is received but no voice on the line, just static noise every time i talk**************
BRU01VG21#
Jan 23 16:20:04.464: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x0, Calling num 50811189
Jan 23 16:20:04.468: ISDN BR0/0/0 Q931: Sending SETUP callref = 0x0004 callID = 0x8006 switch = basic-net3 interface = User
Jan 23 16:20:04.468: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x04
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Calling Party Number i = 0x2081, '50811189'
Plan:Unknown, Type:National
Called Party Number i = 0x80, '0496274256'
Plan:Unknown, Type:Unknown
Sending Complete
BRU01VG21#
Jan 23 16:20:04.504: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x84
Channel ID i = 0x89
Exclusive, B1
BRU01VG21#
Jan 23 16:20:07.648: ISDN BR0/0/0 Q931: RX <- PROGRESS pd = 8 callref = 0x84
Progress Ind i = 0x8088 - In-band info or appropriate now available
BRU01VG21#
Jan 23 16:20:10.100: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8 callref = 0x84
Date/Time i = 0x0E011711140A
Date (dd-mm-yr) = 14-01-23
Time (hr:mnt:sec) = 17:20:10
Jan 23 16:20:10.104: ISDN BR0/0/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x04
BRU01VG21#
Jan 23 16:20:19.752: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x04
Jan 23 16:20:19.836: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x84
Jan 23 16:20:19.840: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x04
BRU01VG21#
When i call a land line, i don't even get a ringback tone and the call just disconnects
*************** call landline, no ringback tone ***************************
BRU01VG21#
Jan 23 16:18:08.493: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x0, Calling num 50811189
Jan 23 16:18:08.497: ISDN BR0/0/0 Q931: Sending SETUP callref = 0x0003 callID = 0x8005 switch = basic-net3 interface = User
Jan 23 16:18:08.497: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x03
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '027551617'
Sending Complete
BRU01VG21#
Jan 23 16:18:08.533: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x83
Channel ID i = 0x89
Exclusive, B1
BRU01VG21#
Jan 23 16:18:10.509: ISDN BR0/0/0 Q931: RX <- PROGRESS pd = 8 callref = 0x83
BRU01VG21#
Jan 23 16:18:22.597: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x03
Jan 23 16:18:22.621: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x83
Jan 23 16:18:22.621: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x03
BRU01VG21#
When i play with the gateway settings, enable the 'media point required" en "enable outbound faststart with G711alaw", i get a 2way voice call for 12 seconds. The call disconnects with the error "
Cause i = 0x80A9 - Temporary failure "
*********************************** Media Termination Point required - Outbount faststart************************
BRU01VG21#
BRU01VG21#
Jan 23 16:40:43.712: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x0, Calling num 50811189
Jan 23 16:40:43.712: ISDN BR0/0/0 Q931: Sending SETUP callref = 0x0006 callID = 0x8008 switch = basic-net3 interface = User
Jan 23 16:40:43.712: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8 callref = 0x06
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Sending Complete
BRU01VG21#
Jan 23 16:40:43.752: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0x86
Channel ID i = 0x89
Exclusive, B1
BRU01VG21#
Jan 23 16:40:47.068: ISDN BR0/0/0 Q931: RX <- PROGRESS pd = 8 callref = 0x86
BRU01VG21#
Jan 23 16:40:49.320: ISDN BR0/0/0 Q931: RX <- CONNECT pd = 8 callref = 0x86
Date/Time i = 0x0E0117112831
Time (hr:mnt:sec) = 17:40:49
Jan 23 16:40:49.320: ISDN BR0/0/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x06
BRU01VG21#
Jan 23 16:41:02.207: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x06
Jan 23 16:41:02.275: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8 callref = 0x86
Jan 23 16:41:02.275: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x06
BRU01VG21#
01-27-2014 01:54 AM
I just attempted
voice service voip
h323
call start fast
I see the call comming in but no voice, and after 9 seconds it's cause code:
01-27-2014 01:57 AM
Look at the following Threads:
https://supportforums.cisco.com/thread/100776
https://supportforums.cisco.com/thread/277774
01-27-2014 02:47 AM
Thanks for the reply's
This is the output from my DSP:
BRU01VG21#show voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
edsp 0001 01 g729r8 p 0.1 IDLE 50/0/1.1
edsp 0002 02 g729r8 p 0.1 IDLE 50/0/1.2
edsp 0003 01 g729r8 p 0.1 IDLE 50/0/2.1
edsp 0004 02 g729r8 p 0.1 IDLE 50/0/2.2
edsp 0005 01 g729r8 p 0.1 IDLE 50/0/3.1
edsp 0006 02 g729r8 p 0.1 IDLE 50/0/3.2
edsp 0007 01 g729r8 p 0.1 IDLE 50/0/4.1
edsp 0008 02 g729r8 p 0.1 IDLE 50/0/4.2
edsp 0009 01 g729r8 p 0.1 IDLE 50/0/5.1
edsp 0010 02 g729r8 p 0.1 IDLE 50/0/5.2
edsp 0011 01 g729r8 p 0.1 IDLE 50/0/6.1
edsp 0012 02 g729r8 p 0.1 IDLE 50/0/6.2
edsp 0013 01 g729r8 p 0.1 IDLE 50/0/7.1
edsp 0014 02 g729r8 p 0.1 IDLE 50/0/7.2
edsp 0015 01 g729r8 p 0.1 IDLE 50/0/8.1
edsp 0016 02 g729r8 p 0.1 IDLE 50/0/8.2
edsp 0017 01 g729r8 p 0.1 IDLE 50/0/9.1
edsp 0018 02 g729r8 p 0.1 IDLE 50/0/9.2
edsp 0019 01 g729r8 p 0.1 IDLE 50/0/10.1
edsp 0020 02 g729r8 p 0.1 IDLE 50/0/10.2
edsp 0021 01 g729r8 p 0.1 IDLE 50/0/11.1
edsp 0022 02 g729r8 p 0.1 IDLE 50/0/11.2
edsp 0023 01 g729r8 p 0.1 IDLE 50/0/12.1
edsp 0024 02 g729r8 p 0.1 IDLE 50/0/12.2
edsp 0025 01 g729r8 p 0.1 IDLE 50/0/13.1
edsp 0026 02 g729r8 p 0.1 IDLE 50/0/13.2
edsp 0027 01 g729r8 p 0.1 IDLE 50/0/14.1
edsp 0028 02 g729r8 p 0.1 IDLE 50/0/14.2
edsp 0029 01 g729r8 p 0.1 IDLE 50/0/15.1
edsp 0030 02 g729r8 p 0.1 IDLE 50/0/15.2
edsp 0031 01 g729r8 p 0.1 IDLE 50/0/16.1
edsp 0032 02 g729r8 p 0.1 IDLE 50/0/16.2
edsp 0033 01 g729r8 p 0.1 IDLE 50/0/17.1
edsp 0034 02 g729r8 p 0.1 IDLE 50/0/17.2
edsp 0035 01 g729r8 p 0.1 IDLE 50/0/18.1
edsp 0036 02 g729r8 p 0.1 IDLE 50/0/18.2
edsp 0037 01 g729r8 p 0.1 IDLE 50/0/19.1
edsp 0038 02 g729r8 p 0.1 IDLE 50/0/19.2
edsp 0039 01 g729r8 p 0.1 IDLE 50/0/20.1
edsp 0040 02 g729r8 p 0.1 IDLE 50/0/20.2
----------------------------FLEX VOICE CARD 0 -----------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
*DSP SIGNALING CHANNELS*
SP2600 001 05 {flex} 32.1.4 alloc idle 0 0 0/1/0 02 0 59/0
SP2600 001 06 {flex} 32.1.4 alloc idle 0 0 0/1/1 02 0 60/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
BRU01VG21#
I see that they have the compressed codec, is this correct? Shouldn't that be G711?
01-27-2014 02:55 AM
Yes it needs to be G711.
You can work thru this as well.
http://voiceonbits.com/2010/08/25/dsp-pvdm-media-resources/
01-27-2014 03:04 AM
Ok,
Can u walk me through how i configure the DSP's with the G711 codec, I have already set up a transcoder and MTP and CFB and they are all registered in Call Manager.
Codec Preference applied to the Voip DialPeer
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
dspfarm profile 100 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729br8
codec g729r8
maximum sessions 2
associate application SCCP
voice-card 0
dspfarm
dsp services dspfarm
01-27-2014 05:17 AM
When i dial into the site. i pickup the phone there but it keeps dialling on the phone were i ring from. So it doesn't seem to realise that the phone is picked up?
01-27-2014 07:31 AM
GW_2811(config)#voice-card 0
GW_2811(config-voicecard)#codec complexity high
01-27-2014 07:32 AM
What does your incoming and outgoing dial peers look like?
01-28-2014 12:13 AM
The codec of the DSP is still on G729r8, i have disabled the transcoder to see if that works but that didn't work either.
My dial-peers look like this:
dial-peer voice 1 pots
tone ringback alert-no-PI
description *** PSTN ***
translation-profile incoming PSTN-in
translation-profile outgoing PSTN-out
preference 1
destination-pattern 0T
incoming called-number .
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 2 pots
huntstop
preference 2
port 0/0/1
forward-digits all
dial-peer voice 100 voip
description *** VoIP to Publisher ***
preference 1
destination-pattern 5081907.
modem passthrough nse codec g711alaw
session target ipv4:10.208.18.20
voice-class codec 1
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
fax-relay ecm disable
fax rate 14400
fax protocol none
ip qos dscp cs3 signaling
no vad
01-28-2014 05:22 AM
In the meanwhile i fixed this issue with using a different protocol to register the voicegateway to callmanager.
Instead of H.323 i am using MGCP now, it looks ok now.
Just have one more question, where can i do the number translations to add the zeros on the display so a redial can work.
Thanks Guys for the assistance
01-28-2014 10:49 AM
Either on the route pattern or you can do a Route List and make add a zero there.
