Problem with call transfer (CME)
mcastillocandia
Hello
I am currently setting up a CME with a SIP Tunk for calls to a remote destination (external numbers).
Calls between CME and external numbers work OK, but if I attempt to put a call on hold or to transfer it, that call ends abruptly.
In a CM scenario, I would force the SIP Trunk to use MTP, but in CME I don't find a way to force SIP Phones to use MTP (there is a mtp command for ephones though).
Is it possible to force mtp on a SIP Phone in CME?
Is there any other possible cause for the failure of Call on Hold and Call Transfer?
I would appreciate any help with this.
14 Replies 14
R0g22
What codec is negotiated for the call ? What codecs does your ITSP support ? What codec is your MOH file ?
For transfer and forwards, ensure the REFER and 302 is disabled. They are enabled by default on IOS. ITSP's don't want a SIP REFER or 302 and would drop the calls.
voice service voip
sip
no supplementary-service sip-refer
no supplementary-service moved-temp
Just check the commands. There might be a syntax error. :P
Hello
thank you very much for your help
the trace of the call indicates codec negotiation g279
g729
g729
CSeq: 2 BYE
Reason: Q.850;cause=127;text="interworking unspecified"
CSeq: 2 BYE
Reason: Q.850;cause=16
voice service voip
 ip address trusted list
  ipv4 192.168.200.2
  ipv4 192.168.100.200
  ipv4 10.235.146.97
  ipv4 0.0.0.0 0.0.0.0
 media disable-detailed-stats
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 no supplementary-service sip handle-replaces
 supplementary-service media-renegotiate
 redirect ip2ip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  emptycapability
  h225 signal overlap
  h225 connect-passthru
  call start interwork
  h245 passthru tcsnonstd-passthru
 sip
  rel1xx supported "rel1xx"
  min-se 90 session-expires 90
  registrar server expires max 600 min 60
  no update-callerid
  early-offer forced
  pass-thru content sdp
Trace Call
IPPBX-CorpDesRancagua#
*Sep  4 21:23:57.628: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:962069504@10.235.146.97:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.200:5060;branch=z9hG4bKCF1EC3
From: "tes" <sip:722605380@192.168.100.200>;tag=25205AE-183C
To: <sip:962069504@10.235.146.97>
Date: Tue, 04 Sep 2018 21:23:57 GMT
Call-ID: AAEFFF60-AFBF11E8-85CD8130-24243124@192.168.100.200
Supported: rel1xx,timer,resource-priority,replaces,sdp-anat
Min-SE:  90
Cisco-Guid: 2844995241-2948534760-2244510000-0606351652
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S4b
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 12
Timestamp: 1536096237
Contact: <sip:722605380@192.168.100.200:5060>
Expires: 300
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 278
v=0
o=CiscoSystemsSIP-GW-UserAgent 9216 267 IN IP4 192.168.100.200
s=SIP Call
c=IN IP4 192.168.100.200
t=0 0
m=audio 8230 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
*Sep  4 21:23:57.669: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
*Sep  4 21:24:01.436: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:962069504@10.235.146.97>;tag=6r5vrpn6-CC-1001
CSeq: 101 INVITE
Contact: <sip:10.235.146.97:5060;transport=udp>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Content-Length: 0
*Sep  4 21:24:02.275: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
*Sep  4 21:24:04.666: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Session-Expires: 300;refresher=uac
Require: timer
P-Asserted-Identity: <sip:10.96.63.129>
Content-Length: 228
v=0
o=HuaweiUAC3000 2217481 2217481 IN IP4 10.235.146.97
s=Sip Call
c=IN IP4 10.235.146.97
t=0 0
m=audio 32270 RTP/AVP 18 101
a=fmtp:101 0-15
a=fmtp:18 annexb=no
*Sep  4 21:24:04.670: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:10.235.146.97:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.100.200:5060;branch=z9hG4bKD01D7
Max-Forwards: 12
CSeq: 101 ACK
Content-Length: 0
*Sep  4 21:24:04.755: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:722605380@192.168.100.200:5060 SIP/2.0
Via: SIP/2.0/UDP 10.235.146.97:5060;branch=z9hG4bKan5jtg00ag9lbo2rhpp0sb0000g00.1
From: <sip:962069504@10.235.146.97>;tag=6r5vrpn6-CC-1001
To: "tes" <sip:722605380@192.168.100.200>;tag=25205AE-183C
CSeq: 1 INVITE
Session-Expires: 300;refresher=uas
Supported: timer
Max-Forwards: 69
Content-Length: 0
*Sep  4 21:24:04.758: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 04 Sep 2018 21:24:04 GMT
CSeq: 1 INVITE
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 278
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
*Sep  4 21:24:04.994: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:722605380@192.168.100.200:5060 SIP/2.0
Via: SIP/2.0/UDP 10.235.146.97:5060;branch=z9hG4bKrnsenc00f000h9vo6qj0.1
CSeq: 1 ACK
Max-Forwards: 69
Content-Length: 228
v=0
o=HuaweiUAC3000 2217481 2217482 IN IP4 10.235.146.97
s=Sip Call
t=0 0
a=fmtp:101 0-15
a=fmtp:18 annexb=no
call transfer
*Sep  4 21:24:13.483: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:192.168.100.200:5060 SIP/2.0
Via: SIP/2.0/UDP 10.235.146.97:5060;branch=z9hG4bKte6uch107oesa8h4k590.1
Call-ID: 89yar78daytf8tavfvcv5rcv6adppfrf@UAC
To: <sip:192.168.100.200:5060>
CSeq: 1 OPTIONS
Max-Forwards: 69
Content-Length: 0
*Sep  4 21:24:13.484: //1112/B4636E2E85CE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.100.200:5060>;tag=252439E-28A
Date: Tue, 04 Sep 2018 21:24:13 GMT
CSeq: 1 OPTIONS
Accept: application/sdp
Content-Length: 385
v=0
o=CiscoSystemsSIP-GW-UserAgent 9587 3636 IN IP4 192.168.100.200
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
*Sep  4 21:24:13.600: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:10.235.146.97:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.100.200:5060;branch=z9hG4bKD1EBC
Min-SE:  90
CSeq: 102 INVITE
Max-Forwards: 12
Timestamp: 1536096253
Expires: 300
Content-Length: 290
v=0
o=CiscoSystemsSIP-GW-UserAgent 9216 268 IN IP4 192.168.100.200
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendonly
*Sep  4 21:24:13.722: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:722605380@192.168.100.200:5060 SIP/2.0
Via: SIP/2.0/UDP 10.235.146.97:5060;branch=z9hG4bKan5jtg00ag9lbo2rhpp0sd0000010.1
CSeq: 2 BYE
Max-Forwards: 69
Content-Length: 0
*Sep  4 21:24:13.726: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 BYE
P-RTP-Stat: PS=67,OS=4020,PR=442,OR=26480,PL=0,JI=0,LA=0,DU=9
Content-Length: 0
*Sep  4 21:24:13.796: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 102 INVITE
Warning: 399 UAC "SS250200F139L990[05537] Request terminated due to Dialog deletion"
Content-Length: 0
*Sep  4 21:24:13.797: //1111/A9932EA985C8/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 12
CSeq: 102 ACK
Content-Length: 0
*Sep  4 21:24:14.590: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.200.2 SIP/2.0
Via: SIP/2.0/UDP 192.168.200.6:5060;branch=z9hG4bK7b2b8a7b
From: <sip:384@192.168.200.2>;tag=f87b204e33a506be27f4eb01-5b8e7e84
To: <sip:384@192.168.200.2>
Call-ID: f87b204e-33a50037-345c47f2-6268ed28@192.168.200.6
Max-Forwards: 70
Session-ID: 1dd6ba2900105000a000f87b204e33a5;remote=00000000000000000000000000000000
CSeq: 1186 REGISTER
User-Agent: Cisco-CP8841/11.7.1
Contact: <sip:18706-42B@192.168.200.6:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-f87b204e33a5>";+u.sip!devicename.ccm.cisco.com="SEPF87B204E33A5";+u.sip!model.ccm.cisco.com="683"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 3600
*Sep  4 21:24:14.591: //1115/B50C588A85D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:384@192.168.200.2>;tag=25247F1-221E
Date: Tue, 04 Sep 2018 21:24:14 GMT
CSeq: 1186 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:384@192.168.200.6:5060>;expires=600
Expires:  600
Content-Type: application/x-cisco-remotecc-response+xml
Content-Length: 188
<?xml version="1.0" encoding="UTF-8"?><x-cisco-remotecc-response><response><code>200</code><optionsind><cmeoption><b2bconf/></cmeoption></optionsind></response></x-cisco-remotecc-response>
Enable the following for me -
debug ccsip message
debug ccsip error
debug voice ccapi inout
Make a test call, collect them in a text file and attach.
Hello
Sorry for a late response.  I attach here what you asked for.
Thanks a lot for your help!
A single file please with all the debugs enabled.
Hi.
Can you share ANI, DNIS and RDNIS info please ?
I have the same problem, so could you solve this issue?
Have you tried contacting ITSP (your provider) about this error? Generally, ITSP expects "Early offer (SDP in in initial invite) but in your case SDP is also there in your 1st Invite.
Regards...
Ashok.
With best regards...
Ashok
Codec should not be a problem because the ITSP accepted the initial INVITE with g729.
The ITSP may be disconnecting the call because of the a=sendonly attribute in the INVITE sent to them when pressing Transfer.
Try adding this command on the router.
voice service voip
 sip
  midcall-signaling block
This will block the INVITE for sendonly being sent to the ITSP. The ITSP leg will always remain connected and not change states.
I have the same problem, I issue this command but not work. So my problem its intermittent, before two or tree calls, the next one it drop.
Dear
Thank you so much this command help me more.
Faisal
Dear
Sreekanth Narayanan
Faisal
thanks dear @Sreekanth Narayanan
we had this issue too
and your solution is working for us..
-- if this helped, please rate by click (Accept as solution) or (Helpful) --
