problem with CIPC call forwarding
ElwinMkanyika
Guys,
Please help me. My client has a 7960 phone configured. He prefers using the CIPC phone instead because he prefers the microphone. I tried configuring call forward to his cell phone but it does not work . Please advice me on how to solve the problem.
ephone-dn  56  dual-line
number 154 no-reg both
pickup-group 7
label xxx 154
name xxx
call-forward busy 099
call-forward noan 989226446321 timeout 10
corlist incoming In001-015-8
huntstop channel
ephone-dn  137  dual-line
number 007 no-reg both
name Group7
call-forward noan 099 timeout 10
ephone  56
video
mac-address 0021.5555.13B3
ephone-template 1
username "xxx" password xxx
type 7960
button  1o56,137
ephone  59
mac-address 50E5.4950.BDAB
username "RomanovIV"
type CIPC
button  1o56,137
I have tried it on a test call but there is no sucess
ephone-dn  5  dual-line
number 999 no-reg both
pickup-group 7
label Faith_Test 999
name Faith_Test
call-forward noan 989268993633 timeout 10
huntstop channel
ephone  6
mac-address 1111.2222.3333
username "Faith_Test"
type CIPC
button  1:5
Does this configuration affect the call forwarding and limit it to only 3 digits ?
transfer-pattern 9.T
transfer-pattern ...
transfer-pattern 8.T
Faith,
Three things that we see is this
1. The CIPC is redirecting the call properly
Called Number=989268993633(TON=Unknown, NPI=Unknown),
   Redirect Number=999, Display Info=Support
2. The second thing is that the voip leg shows us that the correct number is passed to the POTS leg with outgoing dial-peer 34
cisco-username=Support
   ----- ccCallInfo IE subfields -----
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=989268993633
3. The debug isdn shows us what is going on at the POTS leg. The leading 9 is been stripped..
Calling Party Number i = 0x0081, '701000105'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '89268993633'
Now question is why is the 9 stripped off. Without seeing your config I am only taking a guess. And my guess is that you have
1. either configure destination-pattern 9T on dial-peer 34 and by default pots dial-peer will strip the 9 or any defined digit
2. Or configured the wrong forward digits length on dial-peer voice 34 pots.
To resolve this you need to do the ff:
1. Either configure a prefix 9 on that dial-peer or configure forward-digits 12 on it. Please know that all calls will be sent to the PSTN with the 9. If you only want to send this particular number with 9 then you need to create a differenet dial-peer and apply the suggestions I mentioned above
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
9 Replies 9
Ayodeji Okanlawon
You need call-forward pattern .T under telephony-service.
Transfer-pattern ... (will limit xfer of calls to only 3 digits)
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Thank you.
Call forward pattern is already configured but it still does not forward the calls
call-forward pattern ...
Remove the "call-forward pattern ..." and try again. Leave the call-forward pattern .T in place
That still does not work. What else can i check?
Try and remove this
Then do a test again and send me a debug voip ccapi inout and debug isdn q931 if you are using ISDN
aokanlawon I am still in a dilemma. My currect configuration is this :
ephone-dn  10  dual-line
pickup-group 7
name Faith_Test
ephone  6
type CIPC
button  1:10
I have noticed that the 9 is being dropped. By the was, i tried sth like this without the prefix and there was a connection to God knows where. But i read that we always have to include the dialed prefix (98):
call-forward noan 9268993633 timeout 10
Jul 12 12:07:10.965 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:07:19.297 YEKT: //-1/0031A2D20B01/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1#705900999
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jul 12 12:07:19.297 YEKT: //-1/0031A2D20B01/CCAPI/cc_api_call_setup_ind_common:
   Interface=0xC08D825C, Call Info(
   Calling Number=701000105,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1#705900999(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=207764
Jul 12 12:07:19.297 YEKT: //-1/0031A2D20B01/CCAPI/ccCheckClipClir:
   In: Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jul 12 12:07:19.297 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:19.297 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:19.297 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:19.297 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772202416,feature_id:306539
Jul 12 12:07:19.297 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1#705900999(TON=Unknown, NPI=Unknown))
Jul 12 12:07:19.301 YEKT: //207764/0031A2D20B01/CCAPI/cc_process_call_setup_ind:
   Event=0x7070D9A8
Jul 12 12:07:19.301 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1#705900999
Jul 12 12:07:19.301 YEKT: //207764/0031A2D20B01/CCAPI/ccCallSetContext:
   Context=0x69A3F600
   >>>>CCAPI handed cid 207764 with tag 2000 to app "_ManagedAppProcess_Default"
Jul 12 12:07:19.301 YEKT: //207764/0031A2D20B01/CCAPI/ccCallProceeding:
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20167, Params=0x69A32D60, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccCheckClipClir:
   Destination Pattern=999$, Called Number=999, Digit Strip=TRUE
   Called Number=999(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Support
   Account Number=Support, Final Destination Flag=TRUE,
   Guid=0031A2D2-9369-E1FF-0B01-3E010A0A0A2E, Outgoing Dial-peer=20167
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=999
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x7327A3B8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=701000105,(Calling Name=Support)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=999(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20167, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jul 12 12:07:19.305 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:19.305 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:19.305 YEKT:  cc_get_feature_vsa count is 6
Jul 12 12:07:19.305 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772189200,feature_id:306540
Jul 12 12:07:19.305 YEKT: //207765/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 12 12:07:19.305 YEKT: //207765/0031A2D20B01/CCAPI/ccCallSetContext:
   Context=0x69A32D10
Jul 12 12:07:19.305 YEKT: //207764/0031A2D20B01/CCAPI/ccSaveDialpeerTag:
Jul 12 12:07:19.305 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_update_call_info:
   Interface=0x7327A3B8, Call Id=0x32B95
Jul 12 12:07:19.309 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_proceeding:
   Interface=0x7327A3B8, Progress Indication=NULL(0)
Jul 12 12:07:19.309 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_alert:
   Interface=0x7327A3B8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Jul 12 12:07:19.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
Jul 12 12:07:19.313 YEKT: //207764/0031A2D20B01/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jul 12 12:07:19.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Jul 12 12:07:19.313 YEKT: //207765/0031A2D20B01/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=207765
Jul 12 12:07:19.313 YEKT: //207764/0031A2D20B01/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=207764
Jul 12 12:07:19.317 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
Jul 12 12:07:22.373 YEKT: %IPPHONE-6-REG_ALARM: 24: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=Phone-Reg-Rej
Jul 12 12:07:22.393 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:07:22.441 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:07:22.445 YEKT: %IPPHONE-6-REG_ALARM: Name=ATA22900406E101 Load=ATA030203SCCP051201A.zup Last=Initialized
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0xC1B05090, Call Id=207760
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/ccConferenceDestroy:
   Conference Id=0xB139, Tag=0x0
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xB139, Source Interface=0x68E37AFC, Source Call Id=207750,
   Destination Call Id=207760, Disposition=0x0, Tag=0x0
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xB139, Source Interface=0xC1B05090, Source Call Id=207760,
   Destination Call Id=207750, Disposition=0x0, Tag=0x0
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/cc_generic_bridge_done:
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 12 12:07:28.237 YEKT: //207750/768A93A1B6D5/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jul 12 12:07:28.237 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:28.241 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0xC1B05090, Call Id=207760
Jul 12 12:07:28.241 YEKT: //207760/768A93A1B6D5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC1B05090, Tag=0x0, Call Id=207760,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 12 12:07:28.241 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:28.241 YEKT: :cc_free_feature_vsa freeing 69A199E8
Jul 12 12:07:28.241 YEKT:  vsacount in free is 5
Jul 12 12:07:28.257 YEKT: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 3422949866 , call lasted 98 seconds
Jul 12 12:07:28.261 YEKT: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xD780
        Cause i = 0x8090 - Normal call clearing
Jul 12 12:07:28.281 YEKT: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x5780
        Cause i = 0x83BB - Unknown cause value
Jul 12 12:07:28.281 YEKT: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xD780
Jul 12 12:07:28.285 YEKT: //207750/768A93A1B6D5/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68E37AFC, Tag=0x0, Call Id=207750,
Jul 12 12:07:28.285 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:28.285 YEKT: :cc_free_feature_vsa freeing 69A19048
Jul 12 12:07:28.285 YEKT:  vsacount in free is 4
Jul 12 12:07:29.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x7327A3B8, Call Id=207765
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
Jul 12 12:07:29.313 YEKT: //207764/0031A2D20B01/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jul 12 12:07:29.313 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=999
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=999, Called Number=999, Calling Number=701000105, Calling DN=-1 Calling Id=207764,
   Redirect Number=989268993633, Redirect Reason=2
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.313 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.313 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:29.313 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772195920,feature_id:306541
Jul 12 12:07:29.313 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.313 YEKT:  feature_vsa is 69A1A9A8,featname is 0
Jul 12 12:07:29.313 YEKT:  cc_get_feature_vsa count is 6
Jul 12 12:07:29.313 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772198384,feature_id:306542
Jul 12 12:07:29.313 YEKT: : Generating new featurevsa,inserting it
Jul 12 12:07:29.313 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.313 YEKT:  feature_vsa is 69A17608,featname is 0
Jul 12 12:07:29.317 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.317 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.317 YEKT:  cc_get_feature_vsa count is 7
Jul 12 12:07:29.317 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772200624,feature_id:306543
Jul 12 12:07:29.317 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.317 YEKT: : Generating new featurevsa,inserting it
Jul 12 12:07:29.317 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.317 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.317 YEKT: :cc_free_feature_vsa freeing 69A19048
Jul 12 12:07:29.317 YEKT:  vsacount in free is 6
Jul 12 12:07:29.317 YEKT: //207765/0031A2D20B01/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
Jul 12 12:07:29.317 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.321 YEKT: //207765/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7327A3B8, Tag=0x0, Call Id=207765,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
Jul 12 12:07:29.321 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.321 YEKT: :cc_free_feature_vsa freeing 69A1A2A8
Jul 12 12:07:29.321 YEKT:  vsacount in free is 5
Jul 12 12:07:29.321 YEKT:  vsacount in free is 4
Jul 12 12:07:29.321 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.321 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.321 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:29.321 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772189200,feature_id:306544
Jul 12 12:07:29.321 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.321 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.321 YEKT: :cc_free_feature_vsa freeing 69A17608
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=34, Params=0x700D8354, Progress Indication=NULL(0)
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccCheckClipClir:
   Destination Pattern=98[0,3-9]........., Called Number=989268993633, Digit Strip=TRUE
   Guid=B1FA50B4-CB1E-11E1-B289-87E95FB69081, Outgoing Dial-peer=34
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=989268993633
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=999
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=2   fwd_final_type =0
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x68E37AFC, Interface Type=6, Destination=, Mode=0x0,
   Called Number=989268993633(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=34, Call Count On=FALSE,
Jul 12 12:07:29.325 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 12 12:07:29.325 YEKT: :cc_get_feature_vsa malloc success
Jul 12 12:07:29.325 YEKT:  cc_get_feature_vsa count is 5
Jul 12 12:07:29.325 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772189200,feature_id:306545
Jul 12 12:07:29.325 YEKT: //207766/0031A2D20B01/CCAPI/ccIFCallSetupRequestPrivate:
Jul 12 12:07:29.325 YEKT: //207766/0031A2D20B01/CCAPI/ccCallSetContext:
   Context=0x700D8304
Jul 12 12:07:29.325 YEKT: //207764/0031A2D20B01/CCAPI/ccSaveDialpeerTag:
Jul 12 12:07:29.325 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jul 12 12:07:29.325 YEKT:  feature call forward featname is 3
Jul 12 12:07:29.325 YEKT:  feature_vsa is 69A17608,featname is 0
Jul 12 12:07:29.325 YEKT:  cc_get_feature_vsa count is 6
Jul 12 12:07:29.325 YEKT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1772200624,feature_id:306546
Jul 12 12:07:29.325 YEKT: : Generating new featurevsa,inserting it
Jul 12 12:07:29.329 YEKT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 701000105
Jul 12 12:07:29.329 YEKT: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x3F15 callID = 0xBE96 switch = primary-net5 interface = User
Jul 12 12:07:29.329 YEKT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3F15
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
Jul 12 12:07:29.513 YEKT: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xBF15
        Cause i = 0x8381 - Unallocated/unassigned number
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x68E37AFC, Call Id=207766
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Jul 12 12:07:29.513 YEKT: //207764/0031A2D20B01/CCAPI/ccCallReleaseResources:
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=207766
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.513 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x68E37AFC, Tag=0x0, Call Id=207766,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Jul 12 12:07:29.517 YEKT: //207766/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
Jul 12 12:07:29.517 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.517 YEKT: :cc_free_feature_vsa freeing 69A1A2A8
Jul 12 12:07:29.517 YEKT:  vsacount in free is 5
Jul 12 12:07:29.517 YEKT:  vsacount in free is 4
Jul 12 12:07:29.517 YEKT: //207764/0031A2D20B01/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jul 12 12:07:29.517 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_get_transfer_info:
Jul 12 12:07:29.549 YEKT: //207764/0031A2D20B01/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC08D825C, Tag=0x0, Call Id=207764,
Jul 12 12:07:29.549 YEKT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 12 12:07:29.549 YEKT: :cc_free_feature_vsa freeing 69A199E8
Jul 12 12:07:29.549 YEKT:  vsacount in free is 3
Debug isdn q931
Jul 12 12:32:54.857 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:32:58.181 YEKT: %IPPHONE-6-REG_ALARM: Name=ATA22900406E101 Load=ATA030203SCCP051201A.zup Last=Initialized
debug isdn q931 is              ON.
P00-5900-01#
P00-5900-01#
P00-5900-01#term mon
Jul 12 12:33:06.277 YEKT: %IPPHONE-6-REG_ALARM: 24: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=Phone-Reg-Rej
Jul 12 12:33:06.297 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:33:06.345 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
P00-5900-01#
P00-5900-01#
P00-5900-01#
P00-5900-01#
P00-5900-01#
P00-5900-01#
Jul 12 12:33:17.742 YEKT: %IPPHONE-6-REG_ALARM: 24: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=Phone-Reg-Rej
Jul 12 12:33:17.826 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:33:17.870 YEKT: %IPPHONE-6-REG_ALARM: 14: Name=SEP0023049B0E66 Load= SCCP11.8-5-2S Last=UCM-closed-TCP
Jul 12 12:33:22.814 YEKT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 701000105
Jul 12 12:33:22.818 YEKT: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x3F1F callID = 0xBEA0 switch = primary-net5 interface = User
Jul 12 12:33:22.818 YEKT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3F1F
                Standard = CCITT
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
Jul 12 12:33:22.998 YEKT: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xBF1F
Faith,
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=989268993633
aokanlawon Thank you for leading me in the right direction. The 9 was being dropped, that is ok since i had configured it to drop the index. Unfortunately, the translation rule that i had configured did not translate the number so i added
rule 2 /.+/ /3422205005/
voice translation-rule 4
rule 1 /^106$/ /3422205024/
voice translation-profile AONtoPOTS
translate calling 4
Thanks Faith for the nice rating and good luck.
