06-24-2012 10:53 AM - edited 03-16-2019 11:49 AM
Hello all, I've trouble to make connections with my SIP operator. I have Cisco 2911 router. I can to register and when I check registration status show command shows that my router is registered but I can't make any connection I always have wait signal. I thought it is SIP operator problem but with the different SIP operator I have the same problem - when I make connection i have information no Codec - I don't know how to fix it. Please help.
When I chceck call status during the call using command sh sip-ua calls called-number 800900900 I've return:
while connection time I've chear waiting signal
Total SIP call legs:29, User Agent Client:1, User Agent Server:28
SIP UAC CALL INFO
Call 1
SIP Call ID : 2611C8FE-BD5311E1-B982BB06-1C59C87F@64.44.212.11
State of the call : STATE_RECD_PROCEEDING (4)
Substate of the call : SUBSTATE_NONE (0)
Calling Number : 56
Called Number : 800900900
Bit Flags : 0xC00018 0x10800100 0x4280
CC Call ID : 74113
Source IP Address (Sig ): 64.44.212.11
Destn SIP Req Addr:Port : [79.133.193.90]:5060
Destn SIP Resp Addr:Port: [79.133.193.90]:5060
Destination Name : sip.extravoip.pl
Number of Media Streams : 1
Number of Active Streams: 1
RTP Fork Object : 0x0
Media Mode : flow-through
Media Stream 1
State of the stream : STREAM_ACTIVE
Stream Call ID : 74113
Stream Type : voice+dtmf (1)
Stream Media Addr Type : 1
Negotiated Codec : No Codec (0 bytes)
Codec Payload Type : 255 (None)
Negotiated Dtmf-relay : inband-voice
Dtmf-relay Payload Type : 0
QoS ID : -1
Local QoS Strength : BestEffort
Negotiated QoS Strength : BestEffort
Negotiated QoS Direction : None
Local QoS Status : None
Media Source IP Addr:Port: [64.44.212.11]:16476
At the another operator i've identical problem- No Codec
dial-peer command section
dial-peer voice 2 voip
description VOIP outbound
translation-profile outgoing OUT
destination-pattern 0[1-9]........
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711alaw
But I tried with that
Code:
voice-class codec 1
dtmf-relay rtp-nte
where voice class was: (I checked recommended codec settings at the operator website)
Code:
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
SIP-UA configuration section
Code:
sip-ua
credentials username extravoip_XXXXXX password 7 XXXXXXXXXXXXXXXXXXXX realm ipv4:79.133.193.90
authentication username extravoip_XXXXXX password 7 XXXXXXXXXXXXXXXXXXXX
registrar ipv4:79.133.193.90 expires 900 auth-realm extravoip_XXXXXXXX
sip-server ipv4:79.133.193.90
I'VE NO IDEA WHY IT ISN'T WORKING, PLEASE HELP
debug output during the call
Code:
debug ccsip error
Code:
Jun 24 17:18:00.377: //75967/60CCAC2780C1/SIP/Error/ccsip_ipip_media_forking_read_from_TDContainer:
MF: Unable to read data from TD Container..
Jun 24 17:18:00.377: //75967/60CCAC2780C1/SIP/Error/ccsip_ipip_media_forking_forked_leg_config:
MF: TD container cannot be read/container is NULL. Setting of forked call leg failed..
Jun 24 17:18:00.377: //75967/60CCAC2780C1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
MF: Not a Forked SIP leg..
SIP: (75967) Group (a= group line) attribute, level 65535 instance 1 not found.
Jun 24 17:18:00.621: //75967/60CCAC2780C1/SIP/Error/sipSPILocateInviteDialogCCB:
Could not find ccb for response
Jun 24 17:18:01.481: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIFindBranchEntry:
invalid ccb, bName or branch list for sipSPIFindBranchEntry
Jun 24 17:18:01.581: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Orig Container is NULL...should have value
Jun 24 17:18:02.081: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Jun 24 17:18:03.085: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Jun 24 17:18:05.089: //75967/60CCAC2780C1/SIP/Error/sipSPIAddPrivacyHeader:
Jun 24 17:18:12.945: //75969/699BE87E80C7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.945: //75969/699BE87E80C7/SIP/Error/sipSPIUpdateCallInfo:
input argument error
Jun 24 17:18:12.949: //75969/699BE87E80C7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.949: //75969/699BE87E80C7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
MF: Dial-peer is absent..
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.949: //75970/699C853E80C8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.953: //75971/699C853E80C9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.953: //75972/699D216680CA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.957: //75973/699D216680CB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.957: //75974/699DBD8E80CC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.957: //75975/699DBD8E80CD/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.961: //75975/699DBD8E80CD/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.961: //75975/699DBD8E80CD/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.961: //75975/699DBD8E80CD/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.961: //75976/699E59B680CE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.965: //75977/699E59B680CF/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.965: //75978/699EF5DE80D0/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.965: //75979/699EF5DE80D1/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.969: //75979/699EF5DE80D1/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.969: //75979/699EF5DE80D1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.969: //75979/699EF5DE80D1/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.969: //75980/699F920680D2/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.973: //75981/699F920680D3/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.973: //75982/69A02E2E80D4/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.977: //75983/69A02E2E80D5/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.977: //75984/69A0CAEE80D6/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.981: //75985/69A0CAEE80D7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.981: //75986/69A1671680D8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.985: //75987/69A1671680D9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.985: //75988/69A2033E80DA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.985: //75989/69A2033E80DB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.989: //75989/69A2033E80DB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.989: //75989/69A2033E80DB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.989: //75989/69A2033E80DB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.989: //75990/69A29F6680DC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.993: //75991/69A29F6680DD/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.993: //75992/69A33B8E80DE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.997: //75993/69A33B8E80DF/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:12.997: //75994/69A3D7B680E0/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:13.001: //75995/69A3D7B680E1/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:13.001: //75996/69A475E380E2/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Comel-Cisco#
Jun 24 17:18:33.585: //75967/60CCAC2780C1/SIP/Error/sippmh_cmp_tags:
Parse Error in ccb From header
Jun 24 17:18:33.585: //75967/60CCAC2780C1/SIP/Error/sipSPICheckFromToRequest:
Failed FROM/TO Request check - IGNORE IF HAIRPIN CALL
old_from: "Krzysztof Przykładowy" <sip:56@79.133.193.90>;tag=9A65B64-B75
old_to: <sip:800900900@79.133.193.90>
new_from: <sip:800900900@79.133.193.90>;tag=b783bbdaaa8a9a5852f95b0734870e25
new_to: "Krzysztof Przykładowy" <sip:extravoip_138463@79.133.193.90>;tag=9A65B64-B75
Jun 24 17:18:33.585: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg:
Invalid method for (STATE_IDLE): BYE
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.945: //75997/7882989B80E3/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.949: //75998/7883355C80E4/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.949: //75999/7883355C80E5/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.953: //76000/7883D18480E6/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.953: //76001/7883D18480E7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.957: //76002/78846DAC80E8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.957: //76003/78846DAC80E9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.961: //76004/788509D480EA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.961: //76005/788509D480EB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.965: //76006/7885A5FC80EC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.965: //76007/7885A5FC80ED/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.969: //76008/7886422480EE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.969: //76009/7886422480EF/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.973: //76010/7886DE4C80F0/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.973: //76011/7886DE4C80F1/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.977: //76012/78877B0C80F2/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.977: //76013/78877B0C80F3/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.981: //76014/7888173480F4/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.981: //76015/7888173480F5/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.985: //76016/7888B35C80F6/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.985: //76017/7888B35C80F7/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.989: //76018/78894F8480F8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.989: //76019/78894F8480F9/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.993: //76020/78894F8480FA/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.993: //76021/7889EBAC80FB/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.997: //76022/788A87D480FC/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:37.997: //76023/788A87D480FD/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/sipSPIUpdateCallInfo:
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
Jun 24 17:18:38.001: //76024/788A87D480FE/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
06-25-2012 02:41 PM
Can you send a debug ccsip messages and a sh run of your router? Please also send a calling and called number
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
07-07-2012 08:26 AM
____________
Jul 7 15:18:30.207: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:64.44.212.11:60119 SIP/2.0
Via: SIP/2.0/UDP 79.133.193.90:5060;branch=0
To: sip:64.44.212.11:60119
Call-ID: 360b9466-6711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-7711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.211: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-8711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.215: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-9711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-a711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-b711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-c711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.223: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-d711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-e711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-f711d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-0811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.231: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-1811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-2811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.235: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-3811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-4811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-5811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-6811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-7811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-8811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-9811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.247: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-a811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.251: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-b811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-c811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.255: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-d811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-e811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.259: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-f811d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-0911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.263: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-1911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-2911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-3911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-4911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-5911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-6911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.275: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-7911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-8911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-9911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-a911d9a3-f189@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:30.295: //25988/D7BBC7DF9FA4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB44-138B
Date: Sat, 07 Jul 2012 15:18:30 GMT
Server: Cisco-SIPGateway/IOS-15.2.3.T
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4966 3897 IN IP4 64.44.212.11
s=SIP Call
c=IN IP4 64.44.212.11
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Jul 7 15:18:30.299: //25989/D7BBC7DF9FA5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB48-2520
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6081 1975 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.299: //25990/D7BC64079FA6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB48-22E3
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 4390 294 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.299: //25991/D7BD002F9FA7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB4C-1856
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1833 1200 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.299: //25992/D7BD002F9FA8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB4C-A4D
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 3501 3706 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.299: //25993/D7BD9C579FA9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB50-189D
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6318 8533 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.299: //25994/D7BD9C579FAA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB50-1BBF
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 8750 6315 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.299: //25995/D7BE387F9FAB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB54-2201
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 8868 498 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.299: //25996/D7BE387F9FAC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB54-893
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6592 7649 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.303: //25997/D7BED53F9FAD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB58-3D0
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1958 3819 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.303: //25998/D7BED53F9FAE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB58-1CD9
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6614 3762 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.303: //25999/D7BF71679FAF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB5C-252
CSeq: 1 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 711 7018 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:30.303: //26000/D7BF71679FB0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FECB5C-14C8
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 2278 5869 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:35.807: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:585558888@79.133.193.90:5060 SIP/2.0
Via: SIP/2.0/UDP 64.44.212.11:5060;branch=z9hG4bKA8410CE
Remote-Party-ID: "Rafal Kowalski" <47>;party=calling;screen=no;privacy=off
To: <585558888>
Date: Sat, 07 Jul 2012 15:18:35 GMT
Call-ID: DB1243B4-C77D11E1-9FCB9E39-5102EB86@64.44.212.11
Min-SE: 1800
Cisco-Guid: 3615287509-3346862561-2678103609-1359145862
User-Agent: Cisco-SIPGateway/IOS-15.2.3.T
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1341674315
Contact: <47>
Expires: 180
Content-Disposition: session;handling=required
Content-Length: 27147>585558888>47>47>
v=0
o=CiscoSystemsSIP-GW-UserAgent 2168 8586 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=audio 16442 RTP/AVP 8 101 19
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Jul 7 15:18:35.819: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 64.44.212.11:5060;received=64.44.212.11;rport=60119;branch=z9hG4bKA8410CE
To: <585558888>;tag=d0b580866bbefc48e8393552524e82ac.bdce
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="79.133.193.90", nonce="4ff853690000d67814262477f5f7434aeb9b99e3082d083d"
Server: NetCentrica SIP Proxy (OS172-s1)
Content-Length: 0
Warning: 392 79.133.193.90:5060 "Noisy feedback tells: pid=26177 req_src_ip=64.44.212.11 req_src_port=60119 in_uri=sip:585558888@79.133.193.90:5060 out_uri=sip:nat-585558888@79.133.193.90:5060 via_cnt==1"585558888>47>
Jul 7 15:18:35.823: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:585558888@79.133.193.90:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0585558888>47>
Sent:
Via: SIP/2.0/UDP 64.44.212.11:5060;branch=z9hG4bKA85120A
To: <585558888>
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Contact: <47>
Expires: 180
Proxy-Authorization: Digest username="extravoip_138463",realm="79.133.193.90",uri="sip:585558888@79.133.193.90:5060",response="1470363481de335a11ebcb06873634e0",nonce="4ff853690000d67814262477f5f7434aeb9b99e3082d083d",algorithm=md5
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Jul 7 15:18:36.011: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 64.44.212.11:5060;received=64.44.212.11;rport=60119;branch=z9hG4bKA85120A
To: <585558888>;tag=f49de3ddd5305df06cdb2ac4f27f9748-faec
CSeq: 102 INVITE
Content-Length: 0
Warning: 392 79.133.193.90:5060 "Noisy feedback tells: pid=26176 req_src_ip=64.44.212.11 req_src_port=60119 in_uri=sip:585558888@79.133.193.90:5060 out_uri=sip:nat-585558888@79.133.193.90:5060 via_cnt==1"585558888>47>
Jul 7 15:18:36.435: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Record-Route: <79.133.193.90:5060>
To: <585558888>;tag=803dffce77ee7a798b45227e18bc2384
CSeq: 102 INVITE
Server: NetCentrica B2BUA (103)
Content-Length: 188585558888>
v=0
o=root 1660 1660 IN IP4 194.145.204.163
s=session
c=IN IP4 194.145.204.163
t=0 0
m=audio 34972 RTP/AVP 8
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Jul 7 15:18:37.203: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: Anonymous <79.133.193.90:5061>
Content-Length: 18879.133.193.90:5061>585558888>
v=0
o=root 1660 1661 IN IP4 194.145.204.163
s=session
t=0 0
a=ptime:20
a=sendrecv
Jul 7 15:18:37.207: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip::5060 SIP/2.0
To: ;tag=803dffce77ee7a798b45227e18bc2384
Date:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jul 7 15:18:37.211: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
v=0
s=session
t=0 0
a=ptime:20
a=sendrecv
Sent:
Date:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jul 7 15:18:38.139: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
v=0
s=session
t=0 0
a=ptime:20
a=sendrecv
Jul 7 15:18:38.143: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
Date:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jul 7 15:18:40.059: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
v=0
s=session
t=0 0
a=ptime:20
a=sendrecv
Sent:
Date:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jul 7 15:18:48.623: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:585558888@79.133.193.90:5060 SIP/2.0
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674328
Reason: Q.850;cause=16
Jul 7 15:18:49.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674329
Jul 7 15:18:50.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674330
Jul 7 15:18:52.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674332
Jul 7 15:18:55.207: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-a151d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-b151d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.211: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-c151d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-d151d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.215: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-e151d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-f151d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-0251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.223: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-1251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-2251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-3251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-4251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.231: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-5251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-6251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.235: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-7251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-8251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-9251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-a251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-b251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-c251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.247: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-d251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-e251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.251: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-f251d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-0351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.255: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-1351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-2351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.259: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-3351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-4351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.263: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-5351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-6351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-7351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-8351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-9351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.275: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-a351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-b351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-c351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Received:
Call-ID: 360b9466-d351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.283: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 360b9466-e351d9a3-8389@79.133.193.90
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Jul 7 15:18:55.299: //26028/E6A277649FCC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CEC-59F
Date: Sat, 07 Jul 2012 15:18:55 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1956 4106 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.299: //26029/E6A277649FCD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CF0-183E
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 8056 5429 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.299: //26030/E6A314249FCE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CF0-15F0
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 9067 1927 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.299: //26031/E6A3B04C9FCF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CF4-1B55
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1791 6017 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.299: //26032/E6A3B04C9FD0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CF4-39E
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1703 4949 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.299: //26033/E6A44C749FD1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CF8-299
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 6778 7918 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.303: //26034/E6A44C749FD2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CF8-1857
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 3643 8454 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.303: //26035/E6A4E89C9FD3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CFC-1D81
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1466 2518 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.303: //26036/E6A4E89C9FD4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2CFC-14B9
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 8893 7770 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.303: //26037/E6A584C49FD5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2D00-1470
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7422 7293 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.303: //26038/E6A584C49FD6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2D00-477
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 4744 3388 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.303: //26039/E6A620EC9FD7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2D04-4D9
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7874 4023 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:55.307: //26040/E6A620EC9FD8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:64.44.212.11:60119;tag=FF2D04-88
CSeq: 1 OPTIONS
Coontent-Type: application/sdp
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 9539 170 IN IP4 64.44.212.11
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jul 7 15:18:56.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674336
Jul 7 15:19:00.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674340
Jul 7 15:19:04.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674344
Jul 7 15:19:08.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674348
Jul 7 15:19:08.555: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:47@64.44.212.11:60119 SIP/2.0
Via: SIP/2.0/UDP 79.133.193.90:5060;branch=z9hG4bK8aea.a8143a34.0
Via: SIP/2.0/UDP 79.133.193.90:5061;received=79.133.193.90;branch=z9hG4bK6cd73e118fd8c5a105cf98d650be1ec5;rport=5061
Max-Forwards: 69
From: <585558888>;tag=803dffce77ee7a798b45227e18bc2384
To: "Rafal Kowalski"
CSeq: 100 BYE
User-Agent: NetCentrica B2BUA (103)
cisco-GUID: 3615287509-3346862561-2678103609-1359145862
h323-conf-id: 3615287509-3346862561-2678103609-1359145862
Content-Length: 079.133.193.90:5061>
Sent:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Via: SIP/2.0/UDP 79.133.193.90:5060;branch=z9hG4bK8aea.a8143a34.0,SIP/2.0/UDP 79.133.193.90:5061;received=79.133.193.90;branch=z9hG4bK6cd73e118fd8c5a105cf98d650be1ec5;rport=5061
CSeq: 100 BYE
Content-Length: 0
Jul 7 15:19:12.123: //26026/D77CE8D59FA0/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <585558888>
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1341674352
07-08-2012 01:25 AM
I have looked at your log and the problem look slike you are not sending the correct ACK to your provider.
++++++++Your provider sent a 200 OK+++++++++++
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
v=0
s=session
t=0 0
a=ptime:20
a=sendrecv
+++++Now you sent an ACK to the 200 OK++++++++But the ACK is not properly formatted. It doen not have the call details.
Sent:
Date:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
it should be like this..
Remote-Party-ID: "Rafal Kowalski" <47>;party=calling;screen=no;privacy=off47>
To: <585558888>585558888>
Can you attach you sh run. (please dont post it, attach it)
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
