Problem with dial-peer voip and pots
Hello Community,
I am working on a CMExpress version 8.1
Part of the dial-peer configuration listed below:
dial-peer voice 69 pots
description *** Generic outgoing Dial-Peer ***
translation-profile outgoing OUTGOING
destination-pattern 69........
port 0/0/0:15
forward-digits all
dial-peer voice 12 voip
description *** VoIP peer CUCM ***
preference 2
destination-pattern 6[1-9]..
session target ipv4:10.2.1.111
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
The problem is that when i am trying to dial an cell number 6956XXXXXX the router instead of choosing pots, chooses voip and the calls is routed to 6956 extension on another CUCM (as description denotes).
Is there any solution on this, without changing the prefix? Shouldnt pots be prioritarised over voip dial-peer?
George
From the look of things, cucm is nit allowing the other numers to be dialled because its matching  on the dial-peer 2 or 12. Since changing the dial-peer algorithm doesnt help..your only option will be to use prefix on either your voip dial-peer or pots dial-peer
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
6 Replies 6
Ayodeji Okanlawon
This a case of overlapping dial plan. Changing the prefernce on the pots dial-peer will make no difference because the pots dial-peer already has the higher preference. What you can try is to change your dial-peer hunting algorithm to use preference first instead of longest match
try this:
conf t
dial-peer hunt 2
Test again..
Thanks for your reply,
Unfortunately this didnt work, any other suggestions?
thanks!
george
Can you test with this config above and send
debug voip ccapi inout
debug voip dialpeer
107566: Dec 16 00:08:50.920: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
107567: Dec 16 00:08:50.920: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
107568: Dec 16 00:08:50.920: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
107569: Dec 16 00:08:50.920: //-1/D75437A49016/DPM/dpAssociateIncomingPeerCore:
107570: Dec 16 00:08:50.920: //-1/D75437A49016/DPM/dpAssociateIncomingPeerCore:
107571: Dec 16 00:08:50.920: //-1/D75437A49016/DPM/dpMatchSafModulePlugin:
107572: Dec 16 00:08:57.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=7010, Called Number=, Voice-Interface=0x3B5FC48,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
107573: Dec 16 00:08:57.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20007
107574: Dec 16 00:08:57.356: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
107575: Dec 16 00:08:57.356: //-1/DB2A49989017/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7010
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
107576: Dec 16 00:08:57.356: //-1/DB2A49989017/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3B5FC48, Call Info(
   Calling Number=7010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20007, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
107577: Dec 16 00:08:57.356: //-1/DB2A49989017/CCAPI/ccCheckClipClir:
   In: Calling Number=7010(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
107578: Dec 16 00:08:57.356: //-1/DB2A49989017/CCAPI/ccCheckClipClir:
   Out: Calling Number=7010(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
107579: Dec 16 00:08:57.356: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
107580: Dec 16 00:08:57.356: :cc_get_feature_vsa malloc success
107581: Dec 16 00:08:57.356: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
107582: Dec 16 00:08:57.356:  cc_get_feature_vsa count is 1
107583: Dec 16 00:08:57.356: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
107584: Dec 16 00:08:57.356: :FEATURE_VSA attributes are: feature_name:0,feature_time:63184792,feature_id:45905
107585: Dec 16 00:08:57.356: //83001/DB2A49989017/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7010(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
107586: Dec 16 00:08:57.356: //83001/DB2A49989017/CCAPI/cc_process_call_setup_ind:
   Event=0x132FD550
107587: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/ccCallSetContext:
   Context=0x11EB6214
107588: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 83001 with tag 20007 to app "_ManagedAppProcess_Default"
107589: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/ccCallSetupAck:
   Call Id=83001
107590: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
107591: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=83001
107592: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
107593: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
107594: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/ccCallReportDigits:
   (callID=0x14439, digit_event=0x1, enable=TRUE, consume=FALSE)
107595: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=83001
107596: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3B5FC48, callID=0x14439, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
107597: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x3B5FC48, Call Id=83001
107598: Dec 16 00:08:57.360: //83001/DB2A49989017/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
107599: Dec 16 00:08:57.816: //83001/DB2A49989017/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=83001, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x183C970, Rtp Expiration=0x0
107600: Dec 16 00:08:57.816: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
   Source Call Id=83001, Digit=6, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
107601: Dec 16 00:08:57.816: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
107602: Dec 16 00:08:57.816: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6, Peer Info Type=DIALPEER_INFO_SPEECH
107603: Dec 16 00:08:57.816: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6
107604: Dec 16 00:08:57.816: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Result=Partial Matches(1) after DP_MATCH_DEST
107605: Dec 16 00:08:57.816: //-1/DB2A49989017/DPM/dpMatchSafModulePlugin:
   dialstring=6, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
107606: Dec 16 00:08:57.816: //-1/DB2A49989017/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
107607: Dec 16 00:08:58.016: //83001/DB2A49989017/CCAPI/cc_api_call_digit_begin:
   Source Call Id=83001, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0x1844670, Rtp Expiration=0x0
107608: Dec 16 00:08:58.016: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
   Source Call Id=83001, Digit=9, Duration=100,
107609: Dec 16 00:08:58.016: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
107610: Dec 16 00:08:58.016: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=69, Peer Info Type=DIALPEER_INFO_SPEECH
107611: Dec 16 00:08:58.016: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=69
107612: Dec 16 00:08:58.016: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107613: Dec 16 00:08:58.016: //-1/DB2A49989017/DPM/dpMatchSafModulePlugin:
   dialstring=69, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
107614: Dec 16 00:08:58.016: //-1/DB2A49989017/DPM/dpMatchPeersMoreArg:
107615: Dec 16 00:08:58.216: //83001/DB2A49989017/CCAPI/cc_api_call_digit_begin:
   Source Call Id=83001, Digit=5, DigitBeginFlags=0x0,
   Rtp Timestamp=0x184C370, Rtp Expiration=0x0
107616: Dec 16 00:08:58.216: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
   Source Call Id=83001, Digit=5, Duration=100,
107617: Dec 16 00:08:58.216: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
107618: Dec 16 00:08:58.216: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=695, Peer Info Type=DIALPEER_INFO_SPEECH
107619: Dec 16 00:08:58.216: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=695
107620: Dec 16 00:08:58.216: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107621: Dec 16 00:08:58.216: //-1/DB2A49989017/DPM/dpMatchSafModulePlugin:
   dialstring=695, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
107622: Dec 16 00:08:58.216: //-1/DB2A49989017/DPM/dpMatchPeersMoreArg:
107623: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x1854070, Rtp Expiration=0x0
107624: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
107625: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/cc_api_call_digit_end:
107626: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6956, Peer Info Type=DIALPEER_INFO_SPEECH
107627: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6956
107628: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
107629: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchSafModulePlugin:
   dialstring=6956, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
107630: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=12
107631: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCallReportDigits:
   (callID=0x14439, digit_event=0x0, enable=FALSE, consume=FALSE)
107632: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCallReportDigits:
107633: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x3B5FC48, callID=0x14439, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
107634: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/cc_api_call_report_digits_done:
107635: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/cc_api_call_report_digits_done:
107636: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
107637: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107638: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107639: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107640: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchSafModulePlugin:
   dialstring=6956, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
107641: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
107642: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107643: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107644: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107645: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchSafModulePlugin:
107646: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
107647: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=6956, Called Number=6956, Peer Info Type=DIALPEER_INFO_SPEECH
107648: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107649: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107650: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
107651: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
107652: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
107653: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
107654: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
107655: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6956, Called Number=, Voice-Interface=0x0,
107656: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=12
107657: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
107658: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107659: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107660: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107661: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
107662: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
107663: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107664: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107665: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersCore:
107666: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchSafModulePlugin:
   dialstring=6956, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
107667: Dec 16 00:08:58.416: //-1/DB2A49989017/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
107668: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=2, Params=0x1952C33C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
107669: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCheckClipClir:
   In: Calling Number=0186810(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
107670: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCheckClipClir:
   Out: Calling Number=0186810(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
107671: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=6956, Digit Strip=TRUE
107672: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccCallSetupRequest:
   Calling Number=0186810(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6956(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=IT Support
   Account Number=, Final Destination Flag=FALSE,
   Guid=DB2A4998-463A-11E2-9017-B2264453A1E5, Outgoing Dial-peer=2
107673: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=0186810
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=6956
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
107674: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x133493AC, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=0186810,(Calling Name=IT Support)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6956(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=2, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
107675: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
107676: Dec 16 00:08:58.416: :cc_get_feature_vsa malloc success
107677: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
107678: Dec 16 00:08:58.416:  cc_get_feature_vsa count is 2
107679: Dec 16 00:08:58.416: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
107680: Dec 16 00:08:58.416: :FEATURE_VSA attributes are: feature_name:0,feature_time:63187256,feature_id:45906
107681: Dec 16 00:08:58.416: //83002/DB2A49989017/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
107682: Dec 16 00:08:58.416: //83002/DB2A49989017/CCAPI/ccCallSetContext:
   Context=0x1952C2EC
107683: Dec 16 00:08:58.416: //83001/DB2A49989017/CCAPI/ccSaveDialpeerTag:
107684: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/cc_api_call_proceeding:
   Interface=0x133493AC, Progress Indication=NULL(0)
107685: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=28, Progress Indication=INBAND(8), Interface=0x133493AC
107686: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/cc_api_call_disc_prog_ind:
   Event(Progress Indication=0x8), Call Entry(Responsed=TRUE)
107687: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/ccCallDiscProgInd:
107688: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/ccCallDiscProgInd:
   Call Entry(Responsed=TRUE, Disconnect Cause=28)
107689: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/ccConferenceCreate:
   (confID=0x16C97BD4, callID1=0x14439, gcid=DB2A4998-463A11E2-9017B226-4453A1E5, tag=0x0)
107690: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/ccConferenceCreate:
   (confID=0x16C97BD4, callID2=0x1443A, gcid=DB2A4998-463A11E2-9017B226-4453A1E5, tag=0x0)
107691: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/ccConferenceCreate:
   Conference Id=0x16C97BD4, Call Id1=83001, Call Id2=83002, Tag=0x0
107692: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_api_bridge_done:
   Conference Id=0x352A, Source Interface=0x3B5FC48, Source Call Id=83001,
   Destination Call Id=83002, Disposition=0x0, Tag=0xFFFFFFFF
107693: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/cc_api_bridge_done:
   Conference Id=0x352A, Source Interface=0x133493AC, Source Call Id=83002,
   Destination Call Id=83001, Disposition=0x0, Tag=0xFFFFFFFF
107694: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_generic_bridge_done:
107695: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x352A, Destination Call Id=83002)
107696: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x352A, Destination Call Id=83001)
107697: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_api_caps_ind:
   Destination Interface=0x133493AC, Destination Call Id=83002, Source Call Id=83001,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
107698: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
107699: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3B5FC48, Destination Call Id=83001, Source Call Id=83002,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
107700: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/cc_api_caps_ind:
107701: Dec 16 00:09:09.000: //83002/DB2A49989017/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6300)
107702: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3674)
107703: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0186810, Peer Info Type=DIALPEER_INFO_SPEECH
107704: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=0186810
107705: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107706: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
107707: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
107708: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107709: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107710: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
107711: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
107712: Dec 16 00:09:09.000: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2
     2: Dial-peer Tag=12
107713: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=83001
107714: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x352A, Call Id1=83001, Call Id2=83002
107715: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_api_voice_mode_event:
   Call Id=83001
107716: Dec 16 00:09:09.000: //83001/DB2A49989017/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x11EB6214)
107717: Dec 16 00:09:09.004: //83002/DB2A49989017/CCAPI/cc_api_voice_mode_event:
   Call Id=83002
107718: Dec 16 00:09:09.004: //83002/DB2A49989017/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x1952C2EC)
107719: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3B5FC48, Call Id=83001
107720: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=28, Retry Count=0)
107721: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/ccConferenceDestroy:
   Conference Id=0x352A, Tag=0x0
107722: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=83002, Disposition=0x0, Tag=0x0
107723: Dec 16 00:09:26.572: //83002/DB2A49989017/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=83001, Disposition=0x0, Tag=0x0
107724: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_generic_bridge_done:
107725: Dec 16 00:09:26.572: //83002/DB2A49989017/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=28)
107726: Dec 16 00:09:26.572: //83002/DB2A49989017/CCAPI/ccCallDisconnect:
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
107727: Dec 16 00:09:26.572: //83002/DB2A49989017/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
107728: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/ccCallDisconnect:
107729: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/ccCallDisconnect:
107730: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_get_transfer_info:
107731: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=28
107732: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_call_disc_cause_update:
   Call Entry(Disconnect Cause=28)
107733: Dec 16 00:09:26.572: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DB2A4998463A11E29017B2264453A1E5, SetupTime 00:08:57.352 EET Sun Dec 16 2012, PeerAddress 7010, PeerSubAddress , DisconnectCause 1C  , DisconnectText invalid number (28), ConnectTime 00:09:26.572 EET Sun Dec 16 2012, DisconnectTime 00:09:26.572 EET Sun Dec 16 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 875, ReceiveBytes 140000
107734: Dec 16 00:09:26.572: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
107735: Dec 16 00:09:26.572: :Inside cc_build_feature_vsa
107736: Dec 16 00:09:26.572: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
107737: Dec 16 00:09:26.572:  feature call basic
107738: Dec 16 00:09:26.572: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
107739: Dec 16 00:09:26.572: cc_build_feature_vsa attr is fn:TWC,ft:12/16/2012 00:08:57.356,cgn:7010,cdn:,frs:0,fid:45905,fcid:DB2A4998463A11E29017B2264453A1E5,legID:14439
107740: Dec 16 00:09:26.572: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:12/16/2012 00:08:57.356,cgn:7010,cdn:,frs:0,fid:45905,fcid:DB2A4998463A11E29017B2264453A1E5,legID:14439,bguid:DB2A4998463A11E29017B2264453A1E5
107741: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3B5FC48, Tag=0x0, Call Id=83001,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
107742: Dec 16 00:09:26.572: //83001/DB2A49989017/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
107743: Dec 16 00:09:26.572: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
107744: Dec 16 00:09:26.572: :cc_free_feature_vsa freeing 3C41F90
107745: Dec 16 00:09:26.572: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
107746: Dec 16 00:09:26.572:  vsacount in free is 1
107747: Dec 16 00:09:26.592: //83002/DB2A49989017/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=28
107748: Dec 16 00:09:26.592: //83002/DB2A49989017/CCAPI/cc_api_call_disc_cause_update:
107749: Dec 16 00:09:26.592: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId DB2A4998463A11E29017B2264453A1E5, SetupTime 00:09:08.992 EET Sun Dec 16 2012, PeerAddress 6956, PeerSubAddress , DisconnectCause 1C  , DisconnectText invalid number (28), ConnectTime 00:09:26.592 EET Sun Dec 16 2012, DisconnectTime 00:09:26.592 EET Sun Dec 16 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 875, TransmitBytes 147000, ReceivePackets 878, ReceiveBytes 140480
107750: Dec 16 00:09:26.592: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
107751: Dec 16 00:09:26.592: :Inside cc_build_feature_vsa
107752: Dec 16 00:09:26.592: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
107753: Dec 16 00:09:26.592:  feature call basic
107754: Dec 16 00:09:26.592: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
107755: Dec 16 00:09:26.592: cc_build_feature_vsa attr is fn:TWC,ft:12/16/2012 00:08:58.416,cgn:0186810,cdn:6956,frs:0,fid:45906,fcid:DB2A4998463A11E29017B2264453A1E5,legID:1443A
107756: Dec 16 00:09:26.592: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:12/16/2012 00:08:58.416,cgn:0186810,cdn:6956,frs:0,fid:45906,fcid:DB2A4998463A11E29017B2264453A1E5,legID:1443A,bguid:DB2A4998463A11E29017B2264453A1E5
107757: Dec 16 00:09:26.596: //83002/DB2A49989017/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x133493AC, Tag=0x0, Call Id=83002,
107758: Dec 16 00:09:26.596: //83002/DB2A49989017/CCAPI/cc_api_call_disconnect_done:
107759: Dec 16 00:09:26.596: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
107760: Dec 16 00:09:26.596: :cc_free_feature_vsa freeing 3C42930
107761: Dec 16 00:09:26.596: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
107762: Dec 16 00:09:26.596:  vsacount in free is 0
107763: Dec 16 00:09:29.348: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
107764: Dec 16 00:09:29.348: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
107765: Dec 16 00:09:29.348: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
107766: Dec 16 00:09:29.348: //-1/EE3BEC9B901C/DPM/dpAssociateIncomingPeerCore:
107767: Dec 16 00:09:29.352: //-1/EE3BEC9B901C/DPM/dpAssociateIncomingPeerCore:
107768: Dec 16 00:09:29.352: //-1/EE3BEC9B901C/DPM/dpMatchSafModulePlugin:
Thanks a lot for all your help.
Yes prefix is the other option, which i really wanted to avoid....
Again thanks a lot for all the assistance.
george
