problem with downgrade firmware for 7941G CME 4.1(0)
tmowinski
Hello
To correct time stamp on 7941G phones I have to downgrade firmware 8.3 to 7.0(2).
A have all files on flash but when the phone boots up I see these message in log:
037528: *Apr 21 14:01:40.772: 6: Name=SEP001DA2B806EC Load= SCCP41.8-3-1S File Not Found: TERM41.7-0-2-0S
But I can make: more flash:TERM41.7-0-2-0S and I can see this file content.
I have below messages when I type cnf-create command:
CME_ZM_Warsaw(config-telephony)#create cnf-files
CNF file creation is already On
Updating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
CNF files update complete
Where should I look for a solution ??
Thanks in advance
a.baird
Hi Tomasz.
Did you make the TERM41.7 file available to download via the 'tftp-server' command?
-Adam
Yes I did.
Here You are my configuration:
tftp-server flash:TERM41.7-0-2-0S.loads
telephony-service
load 7941 TERM41.7-0-2-0S
Directory of flash:/
40 -rw- 591 Apr 21 2008 14:58:48 +02:00 TERM41.7-0-2-0S.loads
And I stil have the same log messsage:
038267: *Apr 22 08:28:45.428: 6: Name=SEP001DA2B806EC Load= SCCP41.8-3-1S File Not Found: TERM41.7-0-2-0S
thanks in advance
regards
Tomek
