Highlighted
Beginner
Problem with H323gateway and HSRP
I have problem with a H323 gateway and HSRP, when the call is for the secondary gateway I have one way audio, I did a capture in the gateway and all traffic is coursing by the virtual IP (172.16.11.3), so when I unsubscribe the primary gateway I haven´t audio
Anybody know if I need special configuration on the gateway?
Primary Gateway
Interface G0/0
ip address 172.16.11.1 255.255.255.0
standby 1 ip 172.16.11.3
standby 1 priority 105
standby 1 preempt delay minimum 30
standby 1 track 1 decrement 10
standby 1 track 2 decrement 10
duplex full
speed 1000
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.11.1
Secondary Gateway
interface GigabitEthernet0/0
description CONEXION CON LAN CLIENTE
ip address 172.16.11.2 255.255.255.0
standby 1 preempt
duplex full
speed 1000
h323-gateway voip bind srcaddr 172.16.11.2
4 REPLIES 4
Beginner
On ISR G2 routers after
On ISR G2 routers after version 15.1.2T, a change to the IOS was made to use the logigal/standby IP for sourcing calls rather that the physical interface, causing issues with one way voice on secondary router.
You could downgarde te lower version or configure CUBE
CUBE HSRP Configuration guide
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html
NOTE FROM TAC:
I have come across H323 cases, however the theory is not validating and seems like H323 would not be a good design when mixed with redudancy routing protocols like HSRP/VRRP/GLBP
- As there is no concept of bind commands to control signaling and media with H323 deployments
Highlighted
Thank You oleg serstjuk the
Thank You oleg serstjuk the info was useful to me.
Highlighted
Beginner
Re: On ISR G2 routers after
I just encountered this issue today. Really annoying, I had to back-rev my router to the last 15.1 mainline which is 15.1.4M10.
But thanks for the info, it was very helpful to find this.
Highlighted
Sorry Its too late , But how
Sorry Its too late , But how did you solve the issue ?
