Problem with "Forward No Answer Internal
Cesar Arcos
Hi everyone,
I'm facing some issues when trying to forward calls.
I'm think is not a partition issue because of when I use the Forward All option it DOES transfer call correctly but if I try any other option (even using the same DN I used in FW all) the call doesn't complete and send a busy tone, I've tried it in several numbers.
The service parameter is set to 22 seconds.
Im running CM 10.5.2
Thanks in advance for all your support.
Andrew West
Level 4
Level 4
What do you logs say?
Same with RTMT what does that tell you?
ajay1komban
Please  make sure your Call forward CSS  and DN is correct.Also voicemail check box should be un check
Still you are facing problem,please share Rtmt logs here.
