Problem with R2 PSTN Breakout
FPENTEADO
I'm having issues with  calls in/out from and To PSTN E1 R2.
I called the number but the calls are disconnect. We have same issue with incoming calls
Look my configuration and  debug vpm signal
controller E1 0/0/1
 framing NO-CRC4
 line-termination 75-ohm
 ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
 cas-custom 0
  country brazil use dafult
  double-answer
  category 2
  answer-signal group-b 1
  dnis-complete
   1408938 ORG     T0     None        TELE        P#9#0947374856                          D1F
ra084377.oco.brad#sh call history voice callid 1408938
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
Total call-legs: 1
GENERIC:
SetupTime=908936660 ms (13:05:37.896 BR Fri Jan 8 2016)
Index=195211
PeerAddress=#9#0947374856
PeerSubAddress=
PeerId=24
PeerIfIndex=332
LogicalIfIndex=328
DisconnectCause=1F
DisconnectText=normal unspecified (31)
ConnectTime=0 ms (0)
DisconnectTime=908965390 ms (13:06:06.626 BR Fri Jan 8 2016)
CallDuration=00:00:00 sec
CallOrigin=1
ReleaseSource=3
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0x4731D600 0x10000 0xD0BDF 0x66E1C70A]
IncomingConnectionId=[0x4731D600 0x10000 0xD0BDF 0x66E1C70A]
CallID=1408938
Port=0/0/1:0 (1408938)
BearerChannel=0/0/1.1
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=Fernando Penteado
CallerIDBlocked=False
Target tg label=OCO_VIVO
LongDurationCallDetected=no
LongDurCallTimeStamp=
LongDurCallDuration=
OriginalCallingNumber=31000
OriginalCallingOctet=0x0
OriginalCalledNumber=#9#0947374856
OriginalCalledOctet=0x0
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x80
TranslatedCallingNumber=31000
TranslatedCallingOctet=0x0
TranslatedCalledNumber=#9#0947374856
TranslatedCalledOctet=0x0
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x80
GwReceivedCalledNumber=#9#0947374856
GwReceivedCalledOctet3=0x0
GwOutpulsedCalledNumber=947374856
GwOutpulsedCalledOctet3=0x0
GwReceivedCallingNumber=31000
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x81
GwOutpulsedCallingNumber=31000
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x81
DSPIdentifier=0/2:6
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=0
PrecedenceLevel=-1 (PRECEDENCE_LEVEL_NONE)
ra084377.oco.brad#
Jan  8 14:19:17: htsp_timer_stop3 htsp_setup_req
Jan  8 14:19:17:  Orig called num:#9#0947374856
Jan  8 14:19:17: htsp_process_event: [0/0/1:0(1), R2_Q421_IDLE, E_HTSP_SETUP_REQ]
Jan  8 14:19:17: r2_q421_seize(0/0/1:0(1)) E_HTSP_SETUP_REQ DNIS=947374856 ANI=31000
Jan  8 14:19:17: r2_q421_seize(0/0/1:0(1)) Tx SEIZUREvnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(1)] set signal state = 0x0
Jan  8 14:19:17: htsp_timer - 5000 msec
Jan  8 14:19:17: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_SEIZE, E_DSP_SIG_1100]
Jan  8 14:19:17: r2_q421_seize_ack(0/0/1:0(1)) Rx SEIZE ACK
Jan  8 14:19:17: r2_reg_start_dialing(0/0/1:0(1))
Jan  8 14:19:17: r2_reg_process_event: [0/0/1:0(1), R2_REG_IDLE, E_R2_REG_START_DIAL(93)]
Jan  8 14:19:17: r2_reg_start_dial_delay(0/0/1:0(1)) dialout delay 200
Jan  8 14:19:17: r2_reg_timer(0/0/1:0(1)) 200 msec
Jan  8 14:19:17: r2_reg_process_event: [0/0/1:0(1), R2_REG_IDLE, E_R2_REG_EVENT_TIMER(86)]
Jan  8 14:19:17: r2_reg_start_dial(0/0/1:0(1))
Jan  8 14:19:17: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_IDLE R2 Got Event R2_START
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '#'
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '9'
Jan  8 14:19:17: htsp_digit_ready_up(0/0/1:0(1)): Rx digit='1'
Jan  8 14:19:17: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event 1
Jan  8 14:19:17: htsp_digit_ready(0/0/1:0(1)): Rx digit='#'
Jan  8 14:19:17: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '4'
Jan  8 14:19:17: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '7'
Jan  8 14:19:18: htsp_digit_ready_up(0/0/1:0(1)): Rx digit='1'
Jan  8 14:19:18: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event 1
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '#'
Jan  8 14:19:18: htsp_digit_ready(0/0/1:0(1)): Rx digit='#'
Jan  8 14:19:18: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '3'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '7'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '4'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '8'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '5'
Jan  8 14:19:18: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '6'
Jan  8 14:19:22: htsp_digit_ready_up(0/0/1:0(1)): Rx digit='3'
Jan  8 14:19:22: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_A R2 Got Event 3
Jan  8 14:19:22: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '#'
Jan  8 14:19:22:  Check collect call pattern for Brazil
Jan  8 14:19:22:  collect call pattern not configured!!
Jan  8 14:19:22: htsp_digit_ready(0/0/1:0(1)): Rx digit='#'
Jan  8 14:19:22: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_B R2 Got Event R2_TONE_OFF
Jan  8 14:19:22: r2_reg_generate_digits(0/0/1:0(1)): Tx digit '2'un
Jan  8 14:19:24: htsp_timer_stop3
Jan  8 14:19:24: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_SEIZE_ACK, E_DSP_DIALING_DONE]
Jan  8 14:19:24: r2_q421_dial_done(0/0/1:0(1)) E_HTSP_RELEASE_REQ
Jan  8 14:19:24: r2_reg_dial_done(0/0/1:0(1)d all
All possible debugging has been turned off
ra084377.oco.brad#t
Jan  8 14:19:27: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_SEIZE_ACK, E_HTSP_RELEASE_REQ]
Jan  8 14:19:27: r2_q421_clr_fwd(0/0/1:0(1)) E_HTSP_RELEASE_REQ
Jan  8 14:19:27: r2_reg_channel_disconnected(0/0/1:0(1))
Jan  8 14:19:27: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_PROCESS_B R2 Got Event R2_STOP
Jan  8 14:19:27: r2_q421_clr_fwd(0/0/1:0(1)) Tx CLEAR FWDvnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(1)] set signal state = 0x8
Jan  8 14:19:27: htsp_timer - 1000 msec
Jan  8 14:19:27: r2_reg_process_event: [0/0/1:0(1), R2_REG_DIALING, E_R2_REG_DISCONNECT(91)]
Jan  8 14:19:27: r2_reg_disconnect_dial(0/0/1:0(1))
Jan  8 14:19:27: R2 Outgoing Voice(0/1): DSX (E1 0/0/1:0): STATE: R2_OUT_IDLE R2 Got Event R2_STOP
Jan  8 14:19:27: r2_reg_timer_stop(0/0/1:0(1))
Jan  8 14:19:27: htsp_process_event: [0/0/1:0(1), R2_Q421_OG_CLR_FWD, E_DSP_SIG_1000]
Jan  8 14:19:27: r2_q421_clr_fwd_idle(0/0/1:0(1)) Rx IDLE
Jan  8 14:19:27: htsp_timer_stop
Jan  8 14:19:27: r2_q421_clr_fwd_idle(0/0/1:0(1)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/0/1:0(1)] set signal state = 0x8
Jan  8 14:19:27: r2_reg_process_event: [0/0/1:0(1), R2_REG_IDLE, E_R2_REG_DISCONNECT(91)]
Jan  8 14:19:27: r2_reg_disconnect_idle(0/0/1:0(1))erm no
Jan  8 14:19:27: r2_reg_timer_stop(0/0/1:0(1)) mon
11 Replies 11
Samuel T Mathai
Please post sh run &  sh controller e1 <> & deb voice ccapi inout.
#sh run
Building configuration...
Current configuration : 18132 bytes
boot-start-marker
boot system flash0:c3900-universalk9-mz.SPA.153-3.M6.bin
boot-end-marker
aqm-register-fnf
card type e1 0 0
card type e1 0 1
card type e1 0 2
card type e1 0 3
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 E1 0/3/3
network-clock-select 2 E1 0/0/1
isdn switch-type primary-net5
trunk group OCO_VIVO
 hunt-scheme sequential both
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice translation-rule 1
 rule 1 /^[^0]....$/ /#2\0/
voice translation-rule 2
 rule 1 // /24\0/
voice translation-rule 3
 rule 1 /^.....$/ /2\0/
voice translation-rule 4
 rule 1 /^#.#.\(..+\)/ /0\1/
voice translation-rule 5
voice translation-profile EntradaPBX
translate calling 3
 translate called 1
voice translation-profile EntradaPSTN
 translate called 2
voice translation-profile SaidaPBX
 translate calling 5
 translate called 4
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module pvdm 0/2
hw-module pvdm 0/3
dial-control-mib max-size 500
username noc password 7 0123140D560E1516321A1E5921
redundancy
controller E1 0/0/1
 framing NO-CRC4
 cas-custom 0
  country brazil
  seizure-ack-time 78
  category 2
  nc-congestion 2
  dnis-complete
  trunk-group OCO_VIVO
interface Loopback0
 ip address x.x.x.x 255.255.255.255
voice-port 0/0/1:0
 translation-profile incoming EntradaPSTN
 input gain 4
 echo-cancel coverage 32
 no vad
 cptone BR
 timeouts initial 5
 timeouts interdigit 5
 bearer-cap Speech
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 16
 associate application SCCP
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g722-64
 maximum sessions 4
dspfarm profile 3 mtp
 codec g711ulaw
 maximum sessions hardware 10
dial-peer voice 1 pots
 incoming called-number .
 direct-inward-dial
dial-peer voice 2 voip
 voice-class codec 1
 dtmf-relay rtp-nte
dial-peer voice 1005 voip
 description ## Rotas para ClusterADM01 - CUCM Sub 01 ##
 preference 1
 destination-pattern 2.....
 session protocol sipv2
 session target ipv4:10.199.225.102
 voice-class codec 1
 voice-class sip options-keepalive up-interval 15 down-interval 15
dial-peer voice 1006 voip
 preference 2
 session target ipv4:10.199.225.104
 voice-class codec 1
dial-peer voice 1007 voip
 preference 3
 session target ipv4:10.199.225.103
 voice-class codec 1
dial-peer voice 1008 voip
 preference 4
 session target ipv4:10.199.225.105
 voice-class codec 1
dial-peer voice 1009 voip
 preference 5
 session target ipv4:10.199.225.101
 voice-class codec 1
dial-peer voice 1016 voip
 description ## Rotas para ClusterADM01 - Uso Futuro ##
 shutdown
dial-peer voice 24 pots
 trunkgroup OCO_VIVO
 description ## Rotas Opcao 1 VC1.VC2.VC3.DDD.DDI - 4 ##
 destination-pattern #9#0T
E1 0/0/1 is up.
  Applique type is Channelized E1 - unbalanced
  Description: <E1 VIVO - DDR 3684-3311>%### OCOBCDOCOOSP137 ## CABO TOIP 01 PAR 01 - DID VIVO - AZUL 2SS BASTIDOR 13
POSICAO A13 ###$TOIP!@
  No alarms detected.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
Data in current interval (400 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     2 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 340 Unavail Secs
  Data in Interval 1:
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
  Data in Interval 5:
  Data in Interval 6:
  Data in Interval 7:
  Data in Interval 8:
 --More--              0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
  Data in Interval 9:
  Data in Interval 10:
  Data in Interval 11:
  Data in Interval 12:
  Data in Interval 13:
  Data in Interval 14:
  Data in Interval 15:
  Data in Interval 16:
  Data in Interval 17:
  Data in Interval 18:
  Data in Interval 19:
  Data in Interval 20:
  Data in Interval 21:
  Data in Interval 22:
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 860 Unavail Secs
  Data in Interval 23:
     20 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
  Total Data (last 23 15 minute intervals):
     20 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 20660 Unavail Secs
ra084377.oco.brad#sh dial-peer voice 24
VoiceEncapPeer24
    peer type = voice, system default peer = FALSE, information type = voice,
    tag = 24, destination-pattern = `#9#0T',
    voice reg type = 0, corresponding tag = 0,
    allow watch = FALSE
    answer-address = `', preference=0,
    CLID Restriction = None
    CLID Network Number = `'
    CLID Second Number sent
    CLID Override RDNIS = disabled,
    rtp-ssrc mux = system
    source carrier-id = `',    target carrier-id = `',
    source trunk-group-label = `',    target trunk-group-label = `',
    numbering Type = `unknown'
    group = 24, Admin state is up, Operation state is up,
    Outbound state is up,
    incoming called-number = `', connections/maximum = 1/unlimited,
    DTMF Relay = disabled,
    URI classes:
        Destination =
    Destination route-string = None
    huntstop = disabled,
    in bound application associated: 'DEFAULT'
    out bound application associated: ''
    dnis-map =
    permission :both
    incoming COR list:maximum capability
    outgoing COR list:minimum requirement
    Translation profile (Incoming):
    Translation profile (Outgoing):
    incoming call blocking:
    translation-profile = `'
    disconnect-cause = `no-service'
    advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
    mailbox selection policy: none
    trunk-group:
    id = `OCO_VIVO', preference = `'
    type = pots, prefix = `',
    forward-digits default
    session-target = `', voice-port = `',
    direct-inward-dial = disabled,
    digit_strip = enabled,
    register E.164 number with H323 GK and/or SIP Registrar = TRUE
    fax rate = system,   payload size =  20 bytes
    supported-language = ''
    preemption level = `routine'
    bandwidth:
        maximum = 64 KBits/sec, minimum = 64 KBits/sec
    voice class called-number:
        inbound = `', outbound = `'
    dial tone generation after remote onhook = enabled
    mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
    snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
    Time elapsed since last clearing of voice call statistics never
    Connect Time = 0, Charged Units = 0,
    Successful Calls = 1, Failed Calls = 0, Incomplete Calls = 0
    Accepted Calls = 0, Refused Calls = 0,
    Last Disconnect Cause is "10  ",
    Last Disconnect Text is "normal call clearing (16)",
    Last Setup Time = 2120275.
    Last Disconnect Time = 0.
  sh call history voice compact
     37872 ANS     T0     g711ulaw    VOIP        P31000   10.198.197.120:23978   D1F
     37873 ORG     T0     None        TELE        P#9#0947374856                  D1F
Telephony call-legs: 0
SIP call-legs: 1
H323 call-legs: 0
Total call-legs: 1
GENERIC:
SetupTime=21207700 ms (21:34:45.995 UTC Tue Jan 12 2016)
Index=9442
PeerAddress=34736
PeerSubAddress=
PeerId=2
PeerIfIndex=99
LogicalIfIndex=0
DisconnectCause=1
DisconnectText=unassigned number (1)
DisconnectTime=21207700 ms (21:34:45.995 UTC Tue Jan 12 2016)
CallOrigin=2
ReleaseSource=7
InternalErrorCode=1.1.128.11.5.0
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xEB928000 0x10000 0x1036AD 0x66E1C70A]
IncomingConnectionId[0xEB928000 0x10000 0x1036AD 0x66E1C70A]
CallID=37878
SessionId=0
CallReferenceId=0
CallServiceType=Unknown
RTP Loopback Call=FALSE
RemoteIPAddress=10.199.225.102
RemoteUDPPort=31662
RemoteSignallingIPAddress=10.199.225.102
RemoteSignallingPort=53130
RemoteMediaIPAddress=10.198.142.4
RemoteMediaPort=31662
 --More--         SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=rtp-nte
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=sipv2
ProtocolCallId=eb928000-69516369-401d91-66e1c70a@10.199.225.102
SessionTarget=10.199.225.102
SafEnabled=FALSE
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = enabled
CoderTypeRate=g711ulaw
CodecBytes=160
cvVoIPCallHistoryIcpif=0
MediaSetting=flow-through
CallerName=Valter Santos
OriginalCallingNumber=34736
OriginalCalledNumber=26387
DestinationRouteStr=
TranslatedCallingNumber=34736
TranslatedCalledNumber=26387
GwReceivedCalledNumber=26387
GwReceivedCallingNumber=34736
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
LongDurationCallTimerStamp=
LongDurationCallDuration=
Username=34736
PrecedenceLevel=0 (PRECEDENCE_LEVEL_NONE)
CPA Call History Parameters
  CPA Event Status: DISABLE
 RTCP TransmitPackets=0
 RTCP ReceivePackets=0
Jan 12 21:36:52: //-1/36AC93000010/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=31000
   ----- ccCallInfo IE subfields -----
   cisco-ani=31000
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=#9#0947374856
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 12 21:36:52: //-1/36AC93000010/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x14AAA31C, Call Info(
   Calling Number=31000,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=#9#0947374856(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=38059
Jan 12 21:36:52: //-1/36AC93000010/CCAPI/ccCheckClipClir:
   In: Calling Number=31000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=31000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jan 12 21:36:52: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 12 21:36:52: :cc_get_feature_vsa malloc success
Jan 12 21:36:52:  cc_get_feature_vsa count is 1
Jan 12 21:36:52: :FEATURE_VSA attributes are: feature_name:0,feature_time:358818400,feature_id:9611
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=31000(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=#9#0947374856(TON=Unknown, NPI=Unknown))
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/cc_process_call_setup_ind:
   Event=0x28A1518
Jan 12 21:36:52: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number #9#0947374856
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/ccCallSetContext:
   Context=0x10F7C41C
   >>>>CCAPI handed cid 38059 with tag 2 to app "_ManagedAppProcess_Default"
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/ccCallProceeding:
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=24, Params=0x10F718EC, Progress Indication=NULL(0)
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/cc_fill_tg_params:
   Not a cic call
   Trunk Group Select Interface Success;
   Interface=0x150467B8, Selected Interface=1, Selected DSL=-1
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/ccCheckClipClir:
   Destination Pattern=#9#0T, Called Number=#9#0947374856, Digit Strip=TRUE
   Redirect Number=, Display Info=Fernando Penteado
   Account Number=31000, Final Destination Flag=TRUE,
   Guid=36AC9300-0001-0000-0010-36BF66E1C70A, Outgoing Dial-peer=24
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=31000
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=#9#0947374856
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x150467B8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=31000,(Calling Name=Fernando Penteado)(TON=Unknown, NPI=Unknown, Screening=User, Passed,
   Called Number=#9#0947374856(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=24, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=OCO_VIVO, tg_label_flag=2, Application Call Id=)
Jan 12 21:36:52:  cc_get_feature_vsa count is 2
Jan 12 21:36:52: :FEATURE_VSA attributes are: feature_name:0,feature_time:358817056,feature_id:9612
Jan 12 21:36:52: //38060/36AC93000010/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
Jan 12 21:36:52: //38060/36AC93000010/CCAPI/ccCallSetContext:
   Context=0x10F7189C
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/ccSaveDialpeerTag:
Jan 12 21:36:52: //38059/36AC93000010/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=OCO_VIVO, tg_label_flag=TRUE, Call Id=0x94AB
Jan 12 21:36:52: //38060/36AC93000010/CCAPI/cc_api_call_proceeding:
   Interface=0x150467B8, Progress Indication=NULL(0)
Jan 12 21:37:12: //-1/4330EB800010/CCAPI/cc_api_display_ie_subfields:
   cisco-username=02113
   cisco-ani=02113
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=151877
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 12 21:37:12: //-1/4330EB800010/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=02113,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=151877(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=38085
Jan 12 21:37:12: //-1/4330EB800010/CCAPI/ccCheckClipClir:
   In: Calling Number=02113(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=02113(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jan 12 21:37:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 12 21:37:12: :cc_get_feature_vsa malloc success
Jan 12 21:37:12:  cc_get_feature_vsa count is 3
Jan 12 21:37:12: :FEATURE_VSA attributes are: feature_name:0,feature_time:358819296,feature_id:9613
Jan 12 21:37:12: //38085/4330EB800010/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=02113(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=151877(TON=Unknown, NPI=Unknown))
Jan 12 21:37:12: //38085/4330EB800010/CCAPI/cc_process_call_setup_ind:
   Event=0x28A1518
Jan 12 21:37:12: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 151877
Jan 12 21:37:12: //38085/4330EB800010/CCAPI/ccCallSetContext:
   Context=0x10F7D98C
   >>>>CCAPI handed cid 38085 with tag 2 to app "_ManagedAppProcess_Default"
Jan 12 21:37:12: //38085/4330EB800010/CCAPI/ccCallProceeding:
Jan 12 21:37:12: //38085/4330EB800010/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Jan 12 21:37:12: //38085/4330EB800010/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x14AAA31C, Tag=0x0, Call Id=38085,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 12 21:37:12: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 12 21:37:12: :cc_free_feature_vsa freeing 156325D8
Jan 12 21:37:12:  vsacount in free is 2
Jan 12 21:37:21: //38060/36AC93000010/CCAPI/cc_api_call_disconnected:
   Cause Value=31, Interface=0x150467B8, Call Id=38060
   Call Entry(Responsed=TRUE, Cause Value=31, Retry Count=0)
Jan 12 21:37:21: //38059/36AC93000010/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jan 12 21:37:21: //38060/36AC93000010/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=38060
Jan 12 21:37:21: //38060/36AC93000010/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=31)
   Cause Value=31, Call Entry(Responsed=TRUE, Cause Value=31)
Jan 12 21:37:21: //38060/36AC93000010/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Jan 12 21:37:21: //38060/36AC93000010/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x150467B8, Tag=0x0, Call Id=38060,
   Call Entry(Disconnect Cause=31, Voice Class Cause Code=0, Retry Count=0)
   tg for this call is OCO_VIVO success/fail is 0
Jan 12 21:37:21: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 12 21:37:21: :cc_free_feature_vsa freeing 15631D18
Jan 12 21:37:21:  vsacount in free is 1
Jan 12 21:37:21: //38059/36AC93000010/CCAPI/ccCallDisconnect:
   Cause Value=31, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jan 12 21:37:21: //38059/36AC93000010/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x14AAA31C, Tag=0x0, Call Id=38059,
Jan 12 21:37:21: :cc_free_feature_vsa freeing 15632258
Jan 12 21:37:21:  vsacount in free is 0und all
The logs are showing two calls
For first call, the called number sent to telco is #9#0947374856. Is this a valid number?
On the last call the cause code is 1 which means the number dialed is wrong. The called number sent to telco was 151877 which doesn't sound correct.
I think you need to look more at your translation rules as I don't think the right numbering format is sent to telco
Hi People. Calls not outgoing and incoming. The call for #9#047374856 is valid because, my translation rule removes #9#0 and  the call rings on called numbers. Just one ring, but rings and stop.
call disconnect after they answer or just one ring ?
Just one ring and drop.
where is the translation for removing #9#0. I didnt see its applied in any dial-peers.
Is applied on voice-ports. Problem is not translations, because the called phone rings at once and stop.
have you checked with telco ? before they answer and disconnects seems issues with telco.
I'm checking with them.
Hi all
I got whit these parameters
controller E1 0/1/1
framing NO-CRC4
cas-custom 0
  country brazil
  seizure-ack-time 50
  dnis-complete
In order to place calls I had to remove category 2 parameter , and to receive calls I had to apply seizure-ack-time 50.
Kind Regards
