Problems downloading fax offramp tcl script
esanvalero
Level 4
Level 4
Hi.
I'm having troubles to download fax offramp tcl scripts.
All the references at cisco docs points to this URL for downloading the script:
http://www.cisco.com/cgi-bin/tablebuild.pl/tclware
But when you follow the URL there is no way of downloading the file app-faxmail-offramp.2.0.1.1.zip or any other. It seems that the link is broken.
Can you help me?
paolo bevilacqua
Enter filename in cisco.com search box.
Click first result.
paolo bevilacqua
Click first result.
Hi Paolo.
I think that's the only keywork I don't look for...
Thank you very much!
Thank you for the nice rating and good luck!
