Problems Installation CUCM in ESXi5 on UCS210
ricardorojas123
Hi friends of Netpro!
I am trying to install the CUCM version 7 in a UCS c210m2 Server running ESXi 5.0 (only for study purposes), but I am having trouble with the installation,
in the display of the virtual machine I get the error that I attached in a picture.
I appreciate your help and collaboration.
Jaime Valencia
Study what???ESXi 5??? or CUCM??? if the later avoid yourself problems and do this on ESXi 4.1
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Gajanan Pande
Ricardo,
First of all, no earlier versions than CUCM 8.0.2 are supported on UCS. http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Supported_Applications
Also, as of now , UC over UCS is supported only with ESXi 4.1 ( not yet with ESXI 5.0. )
Please rate helpful posts.
GP.
Thank you very much for your comments and help GP.
Not a problem Ric. Thanks for the rating.
Cheers !!
GP
