12-14-2010 08:46 AM - edited 03-16-2019 02:25 AM
Hi all, I have been testing for hours but I can't solve the problem.
I am trying to make a call from an ATA to the PSTN, the ATA is connected to a UC500 and the PSTN is connected to a Cisco 2800 Router.
This is the scenario
ATA ------- CME --------C1801 -----vpn------- C2811 with 4FXO ----- PSTN (941519151)
Well, when i make a call with an ephone registered into CME to number 941519151, the call works well but when i make the same call from a phone connected to the ATA the call doesn't work.
I have this configuration,
CME:
dial-peer voice 97 voip
description ATA
destination-pattern 151
session target ipv4:192.168.254.45
incoming called-number .
dial-peer voice 103 voip
destination-pattern 9........
session target ipv4:10.42.0.6
dial-peer voice 104 voip
destination-pattern 6........
dial-peer voice 105 voip
destination-pattern 5...
dial-peer voice 102 voip
C2811
dial-peer voice 1120 pots
no digit-strip
port 0/1/0
prefix 0
dial-peer voice 1121 pots
preference 1
no digit-strip
port 0/1/1
prefix 0
dial-peer voice 1122 pots
preference 2
no digit-strip
port 0/1/2
prefix 0
dial-peer voice 1123 pots
preference 3
no digit-strip
port 0/1/3
prefix 0
I attach an debug voip dialpeer all from C2811, i don't know how to interpret this debug.
Somebody has any idea?
12-14-2010 10:08 AM
Sounds like a loop. Your debug says:
Calling Number=151, Called Number=941519151
Is Incoming=TRUE
Incoming Dial-peer=97 Is Matched --> voip call leg from ATA to CME - 97 is a CME dial-peer
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1120 ---> 1120 etc are 2811 dial-peers
2: Dial-peer Tag=1121
3: Dial-peer Tag=1122
4: Dial-peer Tag=1123
after matching:
Calling Number=, Called Number=941519151
Is Incoming=FALSE
after matching:
Calling Number=941519151, Called Number=941519151 <--- loop ?
Is Incoming=FALSE
after matching:
Calling Number=941519151, Called Number=,
Is Incoming=TRUE
Result=Success(0); Incoming Dial-peer=1120 Is Matched
Result=Success(0); Incoming Dial-peer=1121 Is Matched
Result=Success(0); Incoming Dial-peer=1122 Is Matched
Result=Success(0); Incoming Dial-peer=1123 Is Matched
after matching:
Calling Number=, Called Number=151
Is Incoming=FALSE
1: Dial-peer Tag=97
2: Dial-peer Tag=111
after matching:
Is Incoming=FALSE
after matching:
Calling Number=, Called Number=151,
Is Incoming=FALSE
1: Dial-peer Tag=97
after matching:
Is Incoming=FALSE
after matching:
etc. etc.
Calling Number=9........, Called Number=
Result=NO_MATCH(-1) After All Match Rules Attempt
What router produces the debug output? CME or 2811 or both?
I've a doubt.
In debug you can see that the call matches dial-peer 97 and dial-peer 1120 (top of debug).
But in your config the dial-peer 97 is configured on the CME, while the dial-peer 1120 is configured on 2811.
12-14-2010 10:18 AM
this debug is from C2811, and i have a dialpeer 97 in both routers
this is the dialpeer 97 in C2811
description pruebasdavid
thank you for your attention
12-14-2010 10:26 AM
Can you capture the output of the command "show voice call status" during call attemp?
Thanks.
12-15-2010 12:43 AM
This is the output of "show voice call status" from C2811
0xAC 171F 0x480C102C 0/1/0 0/1:2 *941519151 None 97/1120
and, if i delete dialpeer 97 from C2811 this is the output
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0xBC 2637 0x480C102C 0/1/0 0/1:1 *941519151 None 111/1120
where dialpeer 111 is
dial-peer voice 111 voip
destination-pattern 1..
session target ipv4:10.40.0.6 <---- That is the IP of CME
12-15-2010 05:13 AM
Can you capture the same debug and the same output of the show command during a call starting from an IPPHONE?
I would compare results.
12-16-2010 12:34 AM
the problem was in the codec.
