Problems upgrading Cisco 8945 to firmware version 9.4.2
Hello, I have 8945 IP phones with firmware version 9.1.2 and I'm looking to upgrade to version 9.4.2, so I tried upgrading first to firmware version 9.1.2.SR-1 and 9.3.4, but always returns to 9.1.2 even if the Phone Load Name is configured with the desired file.
To what version do I have to upgrade to finally run version 9.4.2??
Juan Carlos Arias
Brandon Pierce
Level 4
Level 4
What environment are you on?  If you are on CUCM then make sure all of your Call Managers have the proper firmware and then specify the load or you can set it in Device Defaults so it is server wide.
7 Replies 7
Brandon Pierce
Level 4
Level 4
Hello Brandon, the phones are located in a branch office and running CallManager version 10.5.1, I did all you said, I'm looking if there is some communication problem between both sites.
But based on my question, to upgrade firmware from 9.1.2 to version 9.4.2, have to upgrade first to 9.3.4 and then 9.4.2?
Juan Carlos Arias
I rate your answer by mistake, sorry.
You have to step upgrade them and install the necessary device pack since they require that as well.  Below is a general indication of how to do things as it refers to a 9.4 firmware release.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/firmware/9_4_1/english/release_notes/P415_BK_8E0B5E98_00_8941-8945-release-notes-9_4_1/P415_BK_8E0B5E98_00_8941-8945-release-notes-9_4_1_chapter_00.html
Install Firmware on Cisco Unified Communications Manager
Before using the Cisco Unified IP Phone Firmware Release 9.4(1) with Cisco Unified Communications Manager, you must install the latest firmware on all Cisco Unified Communications Manager servers in the cluster.
Note
The Cisco IP Phone 8941 and 8945 support a new “secure by default” feature starting with Release 9.3(1). Before phones are upgraded to Firmware Release 9.3(1) or later, the Cisco Unified Communications Manager must have Device Pack 8.0.3(24049)/8.5.1(14070)/8.6.2(22030) or higher installed. The phones require this device pack. If the correct device pack is not installed first, the phones cannot successfully register to the Cisco Unified Communications Manager.
Attention:
Firmware Release 9.4(1) can be upgraded only from Release 9.3(4).
This is the events log on phone, the upgrade seems to success but after that there is some error messages.
Any ideas where to look at??
12:08:46, 12/12/2014 : upgrade BOOT8941_8945.0-0-1-0.bin.sgn success
12:08:46, 12/12/2014 : upgrade SCCP8941_8945.9-3-4-17.bin1.sgn from 172.16.31.254
rm: cannot remove '/tmp/ota_LYNETTE.bin': No such file or directory
No need to download locale resources. (Spanish_Colombia/Spanish_Colombia)
download_configuration_process 2312 msgQReceive provision_queueid[0]
provision_flash_callback 917 msgQSend provision_queueid[0]
*** cfgmgr_loads_task 1429 callback return ***
--> dot1x_activate(471) :
while receiving reply
File transfer error.
invalid descriptor
path = /nvdata is exist
FFS Commit to /nvdata/CFG2.
EW: ew_client_task_create fail, either domain/secret is null!
(12)25
(12)6
(12)4
(12)2
(12)7
(12)8
(12)86
(12)15
(12)16
(12)11
(12)12
(12)257
(1)103
ffs_readfile 96 fd == ERROR (/CFG/ealarm.data)
tftp_download_file, 157
tftp_download_file, 164
12:18:48, 12/12/2014 : upgrade ???^ fail (read fail)
Hi Juan
Did you ever get a resolution to this ? I have the same problem on CUCM9.5 (so I don't think the device pack is an issue). I have 7 x 8945's stuck on 9.1(2). I have tried upgrading to 9.1(2)SR1 but the phone just goes back to 9.1(2). Similarly when I tried 9-3-1-19.
Paul
Hello, We were trying to upgrade phone over the WAN and it was hitting bug CSCtq26220, so we upgrade phone to version 9.3.4 locally with a third party TFTP server.
Juan Carlos
Hi Juan Carlos.
These phones are in Singapore over the WAN so yes I'll try a remote TFTP.
Many thanks for getting back.
Paul
