Problems with AA (UC-560)
lblanc
Community Member
When we received a call that is sent to the auto attendant,
if the number called is a 9-digit number (standard in Spain) or a 4-digit short number (used for communication between mobile) operator's circuit seems to operate correctly.
If the call we receive is a 13-digit number, eg. 630385858585, the circuit of AA is blocked in the script Dial By Extension losing the call
I attached scripts used for AA.
lblanc
Community Member
Someone explain me that this could be a problem with a dial-peer.
Here are my dial-peers configuration.
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name internas
name nacionales
name moviles
name internacionales
name tarificacion-especial
name emergencias
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member national-plus
member emergency
member toll-free
dial-peer cor list call-internas
member internas
dial-peer cor list call-nacionales
member nacionales
dial-peer cor list call-moviles
member moviles
dial-peer cor list call-internacionales
member internacionales
dial-peer cor list call-tarificacion-especial
member tarificacion-especial
dial-peer cor list call-emergencias
member emergencias
dial-peer cor list user-internas
member internas
member emergencias
dial-peer cor list user-nacionales
member internas
member nacionales
member emergencias
dial-peer cor list user-moviles
member internas
member nacionales
member moviles
member emergencias
dial-peer cor list user-internacionales
member internas
member nacionales
member moviles
member emergencias
dial-peer cor list user-tarificacion-especial
member internas
member nacionales
member moviles
member emergencias
dial-peer voice 1 pots
description ** incoming dial peer **
translation-profile incoming Anade_0_Entrante
incoming called-number .%
direct-inward-dial
port 0/0/0
no sip-register
dial-peer voice 2 pots
direct-inward-dial
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 10 pots
trunkgroup ALL_FIJ 1
corlist outgoing call-nacionales
description Numeros Fijos Nacionales
translation-profile outgoing Saliente_Sede
destination-pattern 0[89][1-9].......
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
forward-digits 9
dial-peer voice 11 pots
description Numeros Red Inteligente Tarificacion Normal
destination-pattern 0[89]0[012]......
forward-digits 9
dial-peer voice 12 pots
corlist outgoing call-tarificacion-especial
description Numeros Red Inteligente Tarificacion Especial
destination-pattern 0[89]0[3-9]......
forward-digits 9
dial-peer voice 13 pots
trunkgroup ALL_MOV 1
trunkgroup ALL_FIJ 2
corlist outgoing call-moviles
description Numeros de Movil
destination-pattern 0[67]........
forward-digits 9
dial-peer voice 14 pots
description Numeros de Informacion Tarificacion Especial
destination-pattern 0118..
forward-digits 5
dial-peer voice 15 pots
trunkgroup ALL_MOV 2
corlist outgoing call-emergencias
description Numeros de Emergencia
destination-pattern 0112
forward-digits 3
dial-peer voice 16 pots
description Numeros de Emergencia Antiguos
destination-pattern 00[6-9].
forward-digits 3
dial-peer voice 17 pots
description Numeros de Servicios
destination-pattern 001.
forward-digits 3
dial-peer voice 18 pots
corlist outgoing call-internacionales
description Numeros Internacionales
destination-pattern 000T
prefix 00
dial-peer voice 19 pots
description Numeros de Informacion Tarificacion Normal
destination-pattern 01...
forward-digits 4
dial-peer voice 20 pots
trunkgroup ALL_MOV
description Mobiles cortos
destination-pattern 2...
forward-digits 4
dial-peer voice 2020 voip
description ** Autoattendant **
destination-pattern 398
b2bua
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 500
b2bua
codec g711ulaw
no vad
no dial-peer outbound status-check pots
num-exp 934875511 398
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name internas
name nacionales
name moviles
name emergencias
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internas
member nacionales
member moviles
member emergencias
member internas
member emergencias
member internas
member nacionales
member emergencias
member internas
member nacionales
member moviles
member emergencias
member internas
member nacionales
member moviles
member emergencias
member internas
member nacionales
member moviles
member emergencias
direct-inward-dial
port 0/0/0
no sip-register
direct-inward-dial
port 0/0/1
no sip-register
port 0/0/2
no sip-register
port 0/0/3
no sip-register
port 0/4/0
no sip-register
b2bua
codec g711ulaw
no vad
forward-digits 9
forward-digits 9
forward-digits 9
forward-digits 9
forward-digits 5
forward-digits 3
forward-digits 3
forward-digits 3
prefix 00
forward-digits 4
trunkgroup ALL_MOV
forward-digits 4
b2bua
codec g711ulaw
no vad
b2bua
codec g711ulaw
no vad
Any help will be appreciated.
