AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
1080
Beginner
Problems with dial-peer between cisco routers 3925
Good Afternoon ...
I was a problem when wanting to communicate telephony between two routers 3925, on both routers and I have configured the
telephone service (telephony-service), I have discharged my phone and there are internal communication in each of them (I can make
between phones of the same router), every router I've configured a dial-peer intercomunicarlos and this is where the problem arises. When I try to dial a phone in the router A to each router B the phone dials the Ringout timeout and mark Unknow number is completed, when I make a call, the router which owns the phone number of that mark, I run the sh voice call status command and indicates to me that there is a call in progress and you're using it, the dial-peer problem is that it seems that the other router you never call arrives.
I help a lot to have an overview of why this happens.
thanks
Excuse my English is not very good
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
In addition what IOS are you running, calls may be prevented by toll-fraud mechanism if this is 15.1 or newer.
HTH,
Chris
8 REPLIES 8
Hall of Fame Master
Post "sh run" from both routers and identify what numbers you are dialing, also provide "debug voice dialpeer" from both sides.
Chris
Highlighted
Hall of Fame Master
HTH,
Chris
Beginner
Re: Problems with dial-peer between cisco routers 3925
Here the command "sh run" on both routers
Router 1
RouterTelefonia#sh run
Building configuration...
Current configuration : 5604 bytes
! Last configuration change at 16:16:41 MX Sun Dec 1 2013 by icsicorp
! NVRAM config last updated at 15:22:16 MX Sun Dec 1 2013
version 15.1
hostname RouterTelefonia
boot-start-marker
boot-end-marker
enable password icsi
no aaa new-model
clock timezone MX -6 0
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 192.168.201.1 192.168.201.100
ip dhcp excluded-address 192.168.201.201 192.168.201.254
ip dhcp pool Spoke-Data
ip dhcp pool Voice2
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.254
option 150 ip 192.168.2.254
ip dhcp pool Red-Datos
network 192.168.201.0 255.255.255.0
default-router 192.168.201.254
voice-card 0
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
modem passthrough nse codec g711ulaw
license udi pid C3900-SPE200/K9 sn FOC16400V7B
hw-module sm 2
redundancy
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key firewall.cx address 0.0.0.0 0.0.0.0
crypto ipsec transform-set TS esp-3des esp-md5-hmac
crypto ipsec profile protect-gre
set security-association lifetime seconds 86400
set transform-set TS
interface GigabitEthernet0/0
description Link to HubCoatza$ES_LAN$
ip address 192.168.3.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.15.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.254 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.2.254
interface GigabitEthernet0/2
description LAN-Network
ip address 192.168.201.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/3
description WAN-Network
ip address 192.168.100.2 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet2/0
ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet2/1
description Internal switch interface connected to EtherSwitch Service Module
switchport mode trunk
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 172.16.1.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.101.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.102.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.103.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.200.0 255.255.255.0 GigabitEthernet0/3
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
sccp local GigabitEthernet0/1.2
sccp ccm 192.168.2.254 identifier 1 version 4.0
sccp ip precedence 3
sccp
sccp ccm group 2
bind interface GigabitEthernet0/1.2
associate ccm 1 priority 1
associate profile 4 register confprof
sccp ccm group 1
dspfarm profile 1 transcode
description RECURSOS DE TRANSCODE
associate application SCCP
shutdown
dspfarm profile 4 conference
description ICSI
shutdown
dial-peer voice 200 voip
destination-pattern 2...
session protocol sipv2
session target ipv4:192.168.3.254
codec g711alaw
no vad
gatekeeper
shutdown
telephony-service
sdspfarm units 2
sdspfarm tag 1 confprof
conference hardware
max-ephones 10
max-dn 10
ip source-address 192.168.2.254 port 2000
auto assign 1 to 5
system message Corporativo ICSI
max-conferences 8 gain -6
transfer-system full-consult
transfer-pattern 1...
transfer-pattern 4...
ephone-dn  1
number 4000
label Phone 1
description Ext. 4000
name Phone 1
ephone-dn  2
number 4001
label Phone 2
description Ext. 4001
name Phone 2
ephone-dn  3
number 4002
label Phone 2
description Ext. 4002
name Phone 3
ephone  1
device-security-mode none
mac-address 0014.1C31.57F1
type 7912
button  1:1
ephone  2
mac-address 0014.1C31.59DA
type 7912
button  1:2
line con 0
line aux 0
line 130
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
flowcontrol software
line vty 0 4
password icsicorp
login
transport input all
scheduler allocate 20000 1000
end
Router 2
HubCoatza#sh run
Current configuration : 5691 bytes
! No configuration change since last restart
version 15.1
hostname HubCoatza
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 192.168.100.1 192.168.100.253
ip dhcp excluded-address 192.168.101.254
ip dhcp pool Voice
import all
network 192.168.20.0 255.255.255.0
default-router 192.168.20.254
option 150 ip 192.168.20.254
lease infinite
ip dhcp pool Datos-Red
network 192.168.101.0 255.255.255.0
default-router 192.168.101.254
crypto pki trustpoint TP-self-signed-595947439
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-595947439
revocation-check none
rsakeypair TP-self-signed-595947439
crypto pki certificate chain TP-self-signed-595947439
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35393539 34373433 39301E17 0D313331 31313530 30353334
  385A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3539 35393437
  34333930 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  C507C03B 4FBCC60D 85A6FDE7 A3FD55A6 CE9AB147 61E4BA9C 0D046767 F33908A9
  73355DF6 DA6C4AE4 D1DA47B0 FBE4F73D E4612CE2 1F3862C3 6ED23F3B 9C83921F
  E078C9D4 AA4CF4F1 7DBABEC2 F29B59F7 6900CF0B 0B8D8754 46D9C138 D96E5C1A
  182C5D43 A373C177 B78440DF D25A1923 B23B6F03 F79D82D2 02973902 4087076B
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 16801495 3FC9C2D1 D786933B F3A8B681 CED5D0B5 39B02330 1D060355
  1D0E0416 0414953F C9C2D1D7 86933BF3 A8B681CE D5D0B539 B023300D 06092A86
  4886F70D 01010505 00038181 0030B27A 566EBE60 146146C6 4A9BA5A5 65ED23E4
  30E454A3 E805B679 2F995B2F 51AE493E 542FBF50 9614C116 678655F9 00179985
  E45B60AD 5B2E9583 6E66F72F C93AAB9E 81EA8F02 301063A4 8B8238D8 F24218F2
  0AB2A07D 1F30C921 9121F806 FFC65705 61335D51 1D8C9DEE B2FF0589 DE0F1363
  3E1A4286 BB3B2200 A3584ADF 77
        quit
voice-card 0
license udi pid C3900-SPE200/K9 sn FOC16400V86
license accept end user agreement
license boot module c3900e technology-package uck9
hw-module sm 2
redundancy
ip address 192.168.101.254 255.255.255.0
duplex auto
speed auto
ip address 192.168.100.1 255.255.255.0
duplex auto
speed auto
ip address 192.168.16.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2.2
encapsulation dot1Q 20
ip address 192.168.20.254 255.255.255.0
h323-gateway voip bind srcaddr 192.168.20.254
description Link to RouterTelefonia
duplex auto
speed auto
ip address 192.168.30.254 255.255.255.0
no ip address
interface Vlan1
no ip address
ip http server
ip route 172.16.2.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.201.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.202.0 255.255.255.0 GigabitEthernet0/1
nls resp-timeout 1
cpd cr-id 1
control-plane
dial-peer voice 400 voip
destination-pattern 4...
session target ipv4:192.168.3.253
codec g711alaw
gatekeeper
no shutdown
telephony-service
max-ephones 10
max-dn 10
ip source-address 192.168.20.254 port 2000
auto assign 1 to 5
ephone-dn  1
number 2000
label Phone 1
description Ext 2000
name Phone 1
ephone-dn  2
number 2001
label Phone 2
description Ext 2001
ephone  1
mac-address 0014.1C31.5A8A
type 7912
button  1:1
ephone  2
mac-address 0014.1C31.577B
type 7912
button  1:2
line con 0
line aux 0
line 130
no exec
transport input all
transport output none
stopbits 1
line vty 0 4
password icsicorp
transport input all
end
Hall of Fame Master
The destination on the dial-peer needs to be the remote router (telephony-service interface), also some dial peers are SIP, others H323, you need inbound dial peers as well (add "incoming called-number . to a dial peer on each side).
Chris
Beginner
could you be more specific?
Beginner
Here I send the "debugs"
Router 1
RouterTelefonia#debug voice di
RouterTelefonia#debug voice dialpeer
voip dialpeer default debugging is on
RouterTelefonia#sh deb
RouterTelefonia#sh log
Syslog logging: enabled (0 messages dropped, 32 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 118 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 118 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 84 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (8192 bytes):
et0/2, changed state to down
Dec  1 21:21:14.643: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
Dec  1 21:21:14.643: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0, changed state to up
Dec  1 21:21:19.333: %SYS-6-CLOCKUPDATE: System clock has been updated from 21:21:19 UTC Sun Dec 1 2013 to 15:21:19 MX Sun Dec 1 2013, configured from console by console.
Dec  1 21:21:19.637: CEF-HWIDB: EDSP0 LES switching vector set to Null
Dec  1 21:21:19.637: CEF-HWIDB: EDSP0 LES switching vector set to CEF switching
Dec  1 21:21:19.637: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0 added.
Dec  1 21:21:19.839: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.1 added.
Dec  1 21:21:19.839: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.2 added.
Dec  1 21:21:19.839: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.3 added.
Dec  1 21:21:19.839: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.4 added.
Dec  1 21:21:19.839: %EDSP-6-IPV6_ENABLED: IPv6 on interface EDSP0.5 added.
Dec  1 21:21:19.955: %LINK-3-UPDOWN: Interface ephone_dsp DN 1.1, changed state to up
Dec  1 21:21:19.957: %LINK-3-UPDOWN: Interface ephone_dsp DN 2.1, changed state to up
Dec  1 21:21:19.957: %LINK-3-UPDOWN: Interface ephone_dsp DN 3.1, changed state to up
Dec  1 21:21:19.961: %SYS-5-CONFIG_I: Configured from memory by console
Dec  1 21:21:20.347: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
Dec  1 21:21:20.347: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback201, changed state to up
Dec  1 21:21:20.347: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback202, changed state to up
Dec  1 21:21:20.347: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to down
Dec  1 21:21:20.357: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
Dec  1 21:21:20.557: %DTP-5-TRUNKPORTON: Port Gi2/1 has become dot1q trunk
Dec  1 21:21:20.637: %LINEPROTO-5-UPDOWN: Line protocol on Interface EDSP0, changed state to up
Dec  1 21:21:22.105: %LINK-3-UPDOWN: Interface GigabitEthernet2/1, changed state to up
Dec  1 21:21:23.219: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1, changed state to up
Dec  1 21:21:24.129: %ILPM_FAULT-5-ILPM_WARNING: Warning: Ethernet Switch Network Modules with PoE Support need to be reloaded to function properly.
Dec  1 21:21:29.633: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 22:07 by prod_rel_team
Dec  1 21:21:29.633: %SNMP-5-COLDSTART: SNMP agent on host RouterTelefonia is undergoing a cold start
Dec  1 21:21:31.449: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Dec  1 21:21:31.449: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
Dec  1 21:21:31.449: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
Dec  1 21:21:35.269: %IPPHONE-6-REG_ALARM: Name=SEP00141C3159DA Load=CP7912080002SCCP060817A Last=TCP-timeout
Dec  1 21:21:35.371: %IPPHONE-6-REGISTER: ephone-2:SEP00141C3159DA IP:192.168.2.1 Socket:1 DeviceType:Phone has registered.
Dec  1 21:21:39.345: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
Dec  1 21:21:49.191: %IPPHONE-6-REG_ALARM: Name=SEP00141C3157F1 Load=CP7912080002SCCP060817A Last=TCP-timeout
Dec  1 21:21:49.293: %IPPHONE-6-REGISTER: ephone-1:SEP00141C3157F1 IP:192.168.2.2 Socket:2 DeviceType:Phone has registered.
Dec  1 21:21:50.993: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Dec  1 21:22:14.345: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.1.102)
Dec  1 21:23:04.099: %DTP-5-NONTRUNKPORTON: Port Gi2/1 has become non-trunk
Dec  1 21:23:04.595: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1, changed state to down
Dec  1 21:23:04.599: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Dec  1 21:23:09.337: %DTP-5-TRUNKPORTON: Port Gi2/1 has become dot1q trunk
Dec  1 21:23:10.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/1, changed state to up
Dec  1 21:23:40.085: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
Dec  1 22:07:16.643: %SYS-5-CONFIG_I: Configured from http by icsicorp on 192.168.1.102
Dec  2 01:13:41.559: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to up
Dec  2 01:13:42.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to up
Dec  2 01:15:07.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
Dec  2 01:15:09.571: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to up
Dec  2 01:31:30.562: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
Dec  2 01:31:31.562: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
Dec  2 01:31:35.562: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
Dec  2 01:31:36.562: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
Dec  2 01:32:57.460: %SYS-5-CONFIG_I: Configured from console by vty1 (192.168.15.100)
Dec  2 01:34:03.210: %SYS-5-CONFIG_I: Configured from console by vty1 (192.168.15.100)
Dec  2 01:35:50.128: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4000, Called Number=, Voice-Interface=0x2972D4D8,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20001
Dec  2 01:35:50.128: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Dec  2 01:35:50.654: //-1/E8BF4B558002/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2, Peer Info Type=DIALPEER_INFO_SPEECH
Dec  2 01:35:50.656: //-1/E8BF4B558002/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=2
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec  2 01:35:50.656: //-1/E8BF4B558002/DPM/dpMatchSafModulePlugin:
   dialstring=2, saf_enabled=1, saf_dndb_lookup=0, dp_result=-1
Dec  2 01:35:50.656: //-1/E8BF4B558002/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Dec  2 01:36:01.422: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  2 01:36:01.422: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Dec  2 01:36:01.930: //-1/EF7A9EDC8006/DPM/dpMatchPeersCore:
Dec  2 01:36:01.930: //-1/EF7A9EDC8006/DPM/dpMatchSafModulePlugin:
Dec  2 01:36:01.930: //-1/EF7A9EDC8006/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Dec  2 01:36:06.468: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Dec  2 01:36:06.468: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Router 2
HubCoatza#debug voice dialpeer
HubCoatza#sh log
Syslog logging: enabled (0 messages dropped, 33 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 499 messages logged, xml disabled,
                     filtering disabled
                     filtering disabled
    Buffer logging:  level debugging, 499 messages logged, xml disabled,
                    filtering disabled
    Trap logging: level informational, 67 message lines logged
EER_TYPE_VOICE,
Dec  3 22:39:24.015: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20002
Dec  3 22:39:24.015: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Dec  3 22:39:24.523: //-1/97C222738011/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4
   Result=Partial Matches(1) after DP_MATCH_DEST
Dec  3 22:39:24.523: //-1/97C222738011/DPM/dpMatchSafModulePlugin:
   dialstring=4, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Dec  3 22:39:24.523: //-1/97C222738011/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
Dec  3 22:39:24.623: //-1/97C222738011/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=40, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=40
Dec  3 22:39:24.623: //-1/97C222738011/DPM/dpMatchSafModulePlugin:
   dialstring=40, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Dec  3 22:39:24.623: //-1/97C222738011/DPM/dpMatchPeersMoreArg:
Dec  3 22:39:24.721: //-1/97C222738011/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=400, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=400
Dec  3 22:39:24.721: //-1/97C222738011/DPM/dpMatchSafModulePlugin:
   dialstring=400, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Dec  3 22:39:24.721: //-1/97C222738011/DPM/dpMatchPeersMoreArg:
Dec  3 22:39:24.823: //-1/97C222738011/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4000, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4000
   Result=Success(0) after DP_MATCH_DEST
Dec  3 22:39:24.823: //-1/97C222738011/DPM/dpMatchSafModulePlugin:
   dialstring=4000, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Dec  3 22:39:24.823: //-1/97C222738011/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=400
   dialstring=4000, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Dec  3 22:39:24.823: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4000, Called Number=4000, Peer Info Type=DIALPEER_INFO_SPEECH
Dec  3 22:39:24.823: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Dec  3 22:39:24.823: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Dec  3 22:39:24.823: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
   Calling Number=4000, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=400
   Result=SUCCESS(0)
   dialstring=4000, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Beginner
My version of IOS version 15.1 is actually, in this case, I can do?
Beginner
Hey thank you very much.
just change my settings so that calls do not activate the toll-fraud mechanism apart and add the incoming called-number
Thank you very much for your help ...
Content for Community-Ad
August's Community Spotlight Awards
