Problems with FAX server TOPCALL
sat.datos.mdtel
I have a Cisco CallManager release 8.6 and the Cisco Gateway is 2901.
I alsohave  a FAX Server TOPCALL.
The FAX Server is connected to the Cisco Gateway via 2 BRI ports.
The protocol I use is H.323
I configured the BRI Ports on Gateway as Network. The switch-type which I use is "basic-net3"
My problem is that the Layer 3 on the BRI Ports is down. I see the Layer 2 as TEI-ASSIGNED.
How could I get up the Layer 3 of BRI ports?.
I can not get the server to work.
The configuration of BRI ports is the following:
interface BRI 0/1/1
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
isdn skipsend-idverify
Can you help me, please?
0 Replies 0
