Problems with forward calls to cell phones CUCM 6
cvicentep
Hi everybody, i have a problem when i try to forwall calls from my ip phone, i only forward calls for internal users but not for cellphones or external numbers???
5 Replies 5
thisisshanky
Level 11
Level 11
You need a callforward CSS under CFAll under each phone that allows access to local/LD patterns to which you want to call forward.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
This is a new "feature" in 6.x, we found the same thing when we did an upgrade from 4.x
You said me that, i create a CCS callforward and associate this CSS to pattern that permit access to local and cellphones , but i need programming something additional or with this is all ???? .
Yes and that CSS needs to be applied under the Callforward CSS under the line.
Sankar Nair
yeah , you were a rigth that was the problem.
On the other hand, i have two problems maybe you can give me a tip.
1. I install CUCM 6.x with Unity Connection 2 and when try to call to any internal number are produced an delay to 10 second to another numer.
2. When a user 1 call to user 2, and the user 2 don't answer , you can record the message but when the user 1 return and push in the phone the option message dont ear nothing :(
