Programing iphone on CUCM
Adam-USA
We are a big company looking to use around 2000 iPhone's as a wireless connection inside the company.
Does anyone know a good company and it has experience to help us implement that?
Thank you
6 Replies 6
Leo Laohoo
Uhhhhh ... Wut?
2000 VoIP phones using WIRELESS or 2000 Apple iPhones using wireless or 2000 Cisco DECT phones?
Yes, 2000 Apple iPhones. I know many companies using iPhones for inside network communication.
Ok, so the Apple iPhones download the WebEx app and they make calls (voice or video) using this app (wireless or 3G/4G/5G).
Is that what is required?
Jonathan Schulenberg
Voice over WLAN is really hard; you’re going to want this: https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/technotes/8-6/Enterprise_Best_Practices_for_iOS_devices_and_Mac_computers_on_Cisco_Wireless_LAN.pdf
If your building/campus has solid cellular coverage, or an in-building DAS, You may also want to discuss Webex Go with your partner or Cisco account teams. They are just gearing up for Early afield Trial/Beta now.
https://newsroom.cisco.com/press-release-content?type=webcontent&articleId=2203493
Adam-USA
We don't have good DAS coverage inside the building.
We want to see if we can use iPhones on our wireless Infrastructure and registered on the CUCM, to make calls and use AP's, instead of buying Cisco phones and iPads.
Thank you
Contact your Cisco AM/SE/PSS.  This is a major implementation.
This will need a top-down review, redesign and upgrade of the network -- From LAN/WAN to wireless and to unified communications.
