PSTN call to forward to operator extension in SRST mode
rramlal
Beginner
Beginner
Hi Team,
I have the following setup:
CUCM with SIP trunk to a 4331 GW. When not in SRST mode, the FXO port using connection plar and a voip dial peer hits the AA extension. However in SRST mode, I would like to hit an operator extension. How can I do this? Since the connection plar points to AA. I was thinking of using a translation rule on another dial peer.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Configure a translation rule to be used when SRST kicks in
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_call_handling.html
java
if this helps, please rate
Thanks Jaime for your response, but I have sip srst set up using SRST manager to push the configs.
After reading the guide, it is referencing a call-manager-fall-back to apply the translation rule on. However with SIP srst configs that is pushed to the router there is no fall-back command. Do i add this command? or there is another way to setup?
Hi All,
Any ideas for this? Its E-SRST with a sip trunk.
Recognize Your Peers
