ā12-10-2010 11:44 PM - edited ā03-16-2019 02:22 AM
hi,
im trying to config T1 in PSTN router which is back to back connected to a router, but did not succedd , here is the error
msg im getting when i debug isdn q931 on PSTN & HQ Router :
HQ#BAD FRAME()BAD FRAME()BAD FRAME()BAD FRAME()
*Dec 11 08:01:07.187: ISDN Se0/0/0:23 Q931: Ux_DLRelInd: DL_REL_IND received fro
m L2
*Dec 11 08:01:16.187: ISDN Se0/0/0:23 Q931: Ux_DLRelInd: DL_REL_IND received fro
m L2
show isdn status on both the rotuters are same:
HQ#sh isdn status
Global ISDN Switchtype = primary-4ess
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-4ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x8000FFFF
Number of L2 Discards = 0, L2 Session ID = 66
Total Allocated ISDN CCBs = 0
HQ#
HQ#
HQ#
HQ#sh isdn status
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
Number of L2 Discards = 0, L2 Session ID = 69
HQ#
HQ#
attached are the HQ & PSTN Router Config !!!
This is my first time back to back router connectivity.
Can any body suggest please ??
Solved! Go to Solution.
ā12-11-2010 09:03 AM
glad it worked. dont forget tor rate useful posts
ā12-11-2010 02:21 AM
You need to have one end providing clock and serving as the network side.
Eg on your PSTN router you will have
int s0/1/0:23
clock source internal
isdn protocol-emulate network
ā12-11-2010 08:58 AM
Hi Aokanlawon,
Thanks for your help it worked with your suggestion.
