PSU Redundancy in CUCM 8.6 vs 8.5
I have two servers. one is running 8.6 and another is running 8.5
on 8.5 i can see PSU redundancy using command:
admin:show environment power-supply
Power supply #1
Present : Yes
Redundant: Yes
Condition: Ok
Hotplug : Supported
Power supply #2
Present : Yes
Redundant: Yes
Condition: Ok
Hotplug : Supported
How can i see the same current REDUNDANCY Level of PSU on CUCM 8.6?
There are old MCS series servers
Aman Soi
what happens when u run same commands on CUCM 8.6?
regds,
aman
gives me only for both PSU. :( no info on redundancy..
status: ok
I believe the output of command depends on MCS model whether it is IBM or HP.
I checked on IBM , it shows power-supply OK while HP shows Redundant : Yes and Hotplug: Supported.
I also checked the CLI guide and have attached the snapshot.
regds,
aman
