Publisher and Subscriber configuration
Hello Everyone,
I have been working on one project which has 1 publisher and 4 subscriber. My task is to add some new sites to the head office.
1.Phones will register to HO call manager and branch router will function as H.323 Gateway and SRST router when WAN link goes down
2.Cisco Unity is present at HO but at branch site, client asks to use CUE which is present in Router.
3.Need to configure confrencing and transcoding.
My question is, when i will add phones, MGRL list, SRST reference, Device pool, Gateway, CSS, Partition etc on Publisher. Do i also need to repeat the same task on the subscribers.
As far as i know, we do the configuration like adding phones on publisher and it will be synchronized with the subscriber. Will it be same for the other configuration like MGRL list, SRST reference, Device pool, Gateway, CSS, Partitions.
Kindly advice on the above issue.
Thanks In advance
FRK
Terry Cheema
Yes you are right. You will need to do all the configuration only once and on the publisher server.
Please mark the question as answered and rate if you find the post helpful.
Terry Cheema
Thanks for your reply and its clear to me.
Not a problem Fazal. Glad that helped!
