PVDM upgrade and conference resources allocation
Kalliopi Vazima
Hello everyone,
i got stuck in a case where in an ISR4351 i have configured a dspfarm profile for conference like below
dspfarm profile 1 conference
 codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum conference-participants 16
maximum sessions 2
associate application SCCP
the PVDM resources are used for both ad hoc conference and for conference now option too.
I have been asked for an upgrade of the resources in order to cover two cases
1) add one more session with 32 maximum participant in the current infrastructure
2) add one more session with 64 maximum participants for a new meet me option
The question is if for the first requirement the only option is to configure a second dspfarm profile like
dspfarm profile 2 conference
codec...
maximum conference-participants 32
maximum sessions 1
and add the additional cfb to the MRGL already used by existing users?
What about the second requirement? I was thinking about configuring one more dspfarm profile like
dspfarm profile 3 conference
codec...
maximum conference-participants 64
maximum sessions 1
but i m not really sure how this cfb resource will be allocated from the call manager to users of the new meet me conference.
Any thoughts?
Thanks in advance
Kalliopi
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Jonathan Schulenberg
That is not going to work. CUCM will allocate the bridge when a call initially needs the media resource (i.e. the third participant in an ad-hoc conference or the first person joins for rendezvous Conference Now or MeetMe). It has no idea how many people will eventually join and is not able to change resource bridges mid-call. You need to choose a consistent maximum participant limit.
Also, conferences that large are going to be unwieldy since Conference Now and MeetMe lack active speaker indications and the ability to mute others. You may want to look at Webex, CMS, or even an FOSS option such as Jitsi which, I believe, has a SIP trunk option for dial-in.
Thank you Jonathan for you prompt reply. Is there any document that refers to your reply?
I was thinking that if i create a difference profile, different resources will be available for the call manager in order to be allocated through MRGL to suitable users. i understand this is not going to happen, correct?
Kalliopi
