02-23-2019 11:38 PM
im trying to understand sip debugging i came across this document which says the following
CUBE:10.100.0.74
CUCM:10.100.0.14
Next the CUBE receives a trying from CUCM. The call-ID help us to know where these responses are coming from.
002793: Jun 6 16:07:28.396: //260863/8C38FA5E95E3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.100.0.74:5060;branch=z9hG4bK7953C1859
From: <sip:07455900064@10.100.0.74>;tag=4C85762C-1A2D
To: <sip:901127653485@10.100.0.14>
Date: Wed, 06 Jun 2012 16:07:28 GMT
Call-ID: 8C394872-AF2811E1-95E98F4D-5D7E5E41@10.100.0.74
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
it says the cube receives trying from the cucm yet the log shows the sender is the cube not the cucm from below
Via: SIP/2.0/TCP 10.100.0.74:5060;branch=z9hG4bK7953C1859 ##cube ip?
From: <sip:07455900064@10.100.0.74>;tag=4C85762C-1A2D ##cube ip?
can someone explain please
Solved! Go to Solution.
02-24-2019 12:21 AM
02-24-2019 12:01 AM
02-24-2019 12:05 AM
02-24-2019 12:21 AM
02-24-2019 12:46 AM
02-24-2019 01:04 AM
02-24-2019 01:05 AM
1) 002793: Jun 6 16:07:28.396: //260863/8C38FA5E95E3/SIP/Msg/ccsipDisplayMsg:
Received:
=====> Indicates it has been received
2) Else if you have packet capture you can see the Source and Destination IP to see the direction in which message is travelling.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
02-24-2019 01:14 AM
please what does "Remote-Party-ID" in the debugging means?
02-24-2019 01:23 AM
02-24-2019 01:30 AM
02-24-2019 01:37 AM
02-24-2019 03:02 AM
02-24-2019 03:42 AM
02-24-2019 02:00 AM
