11-05-2018 03:45 AM - edited 03-17-2019 01:40 PM
I would like to apply QoS to VoiP traffic for Avaya phones on our work network. There are a number of really old switches (some wont even have QoS capapbility) but we also have an ASA. I know how to configure QoS on the ASA.
My question is, will the VoiP packets even have the DSCP EF value by the time they get to the ASA, as there is no QoS configured on the switches - or will the DSCP value be 0 & hence traffic treated as BE as there are no CoS-to-DSCP mappings?
If that is the case, then I would have to consider prioritisation of VoiP traffic 'only on the ASA' based on source IP range & ACL.
Azam
11-05-2018 05:55 AM
If there is no QoS enabled on the switch then the QoS markings should be preserved across the switch.
11-05-2018 06:09 AM
Hi Chris,
I thought that a switch interface had to be configured with (eg.) auto qos voip trust to trust the markings from the IP phone?
11-05-2018 06:13 AM
It does if you have QoS enabled globally on the switch, if no QoS is enabled then all markings are preserved onto the next hop.
11-05-2018 06:41 AM
I understand now, thank you!
I'm sure I'll be back for further questions as I work my through the Cisco QoS book :)
Azam
11-08-2018 01:43 PM
Span the incoming and or the uplink port and you can check for sure. Rgs ashish
