11-08-2018 10:04 AM - edited 03-17-2019 01:41 PM
good day everyone - i have some confusion in mind in regards to QoS, here is what questioning;
1 ACL base QoS
- if i create a ACL called VOIP (see below); within this ACL i have RTP and Signaling, when i create my class-map to match-all or any how does it work? because when i create my policy-map and say class XXX set dscp EF for voice and one for signally how does it classify according if it all in one ACL? (not sure if this is clear but....)
Extended IP access list Voip-QoS |
10 permit udp any any range 16384 32767 |
11 permit tcp any any eq 5060 |
12 permit tcp any any range 2000 2002 |
13 permit tcp any any eq 1720 |
14 permit tcp any any range 11000 11999 |
15 permit tcp any any |
16 permit ip any any |
If i say match-all it will match ALL as per ACL list, if i say match-any will it match according to first come first serv?
Please help.
Solved! Go to Solution.
11-08-2018 02:33 PM
11-08-2018 02:52 PM
and that what i also said in my earlier post:
you don't apply the acl to the interface - you apply the service-policy, see below example:
interface fa0/0
service-policy input voip-and_be
regards, mk
11-08-2018 11:13 AM
11-08-2018 11:18 AM
Thanks for reaching out Anthony - thats a very good point! yes i can separate them but if i can only apply 1 ACL to an interface how will that work? i think i'm not seeing the bigger picture here.
MR
11-08-2018 02:33 PM
11-08-2018 02:44 PM
11-08-2018 02:52 PM
interface fa0/0
regards, mk
11-08-2018 02:56 PM
11-08-2018 12:57 PM
im in the middle of learning QoS myself - so perhaps the more experienced guys might be able to verify if this is correct:
class-map voip-traffic
match ip access-group 101
policy-map voip-and-be
class voip-traffic
set ip dscp ef
class class-default
set ip dscp default
access-list 101 ext permit udp any any range 16384 32767
regards, mk
11-08-2018 01:06 PM
11-08-2018 01:12 PM - edited 11-08-2018 01:14 PM
you'd normally use class-maps to define the different types of traffic - eg. voip media & voip signalling
i think match ip rtp - will match only the VoIP payload
interface fa0/0
like i said, im new to this myself, - but you can still rate if helpful/solved :)
regards, mk
11-08-2018 01:49 PM - edited 11-08-2018 01:50 PM
Have you reviewed the QoS Bible https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book/QoSDesign.html#66797 maybe a few years old but still useful to see how to apply QoS. rgs ashish
11-08-2018 02:10 PM
