QOS config
Network Pro
Beginner
Beginner
Hi all,
i am pretty new to VOIP. we have a core switch and few access switches connected to it. All the ip phones are Nortel and are connected to the access switches. Just wondering if anyone can help me providing the config for adding QoS to it please? all ip phones are on a seperate vlan to the data vlan
4 REPLIES 4
ashok_boin
Contributor
Contributor
Pls refer Cisco Enterprise QoS SRND to customize QoS for your design.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
Regards...
-Ashok.
With best regards...
Ashok
thanks for the reply..just wondering if anyone has a sample config for easy understanding to start with ?
THanks
I have just found out a sample config for Nortel phones on switches.
It may help you....
http://www.tek-tips.com/viewthread.cfm?qid=1055543
Regards..
-Ashok.
Ashok
thanks for your help
