Community Helping Community
239
Beginner
QoS in Cisco2960 Switches for a Call Center
I am working in the implementation of a call center with up to 120 agents based on Avaya MG8300. All the agents will use avaya soft phone and the switches are Cisco 2960.
I like to have some tips and advise to properly set up QoS in the Switches.
I think auto qos feature is designed to work with Cisco IP phones not third party.
Because all the agents will use soft phone I wouldn't assign QoS by physical port or VLAN, so how should I set the equipment to classify voice and data packets coming from the same device?
I will appreciate all assistance you can give me.
1 REPLY 1
Highlighted
Participant
Re: QoS in Cisco2960 Switches for a Call Center
Assuming the Avaya is marking it's voice traffic as ef and signaling as either af31 or cs3:
mls qos map cos-dscp 0 8 16 26 32 46 48 56
class-map match-all RTP
match ip dscp ef
class-map match-all Control
match ip dscp 24 26
policy-map SoftPhone
class RTP
police 1000000 4096
exceed-action drop
class Control
police 1000000 4096
exceed-action drop
int range fa0/1 - 48
service-policy input SoftPhone
wrr-queue bandwidth 10 20 70 1
no wrr-queue cos-map
wrr-queue cos-map 1 0 1
wrr-queue cos-map 2 2 4
wrr-queue cos-map 3 3 6 7
wrr-queue cos-map 4 5
On the uplinks, put this under the interface:
int fa0/0
mls qos trust cos
Again, this is not knowing how the Avaya is marking the traffic. Are you going to be using voice vlans?
Please rate if this helped.
Content for Community-Ad
FusionCharts will render here
