QOS Methods with mixed VOIP Phones
jonesm111
We currently have several sites with mixed VOIP phones consisting of Siemens Hipath and Asterisk with Snom phones.
Our WAN's are all linked with Sprint MPLS with our routers being mostly Cisco 2821's wich then connect to 6500's using CEF 720's then 4500's for Access layer using ws-x4515 sup cards.
What would be the best method of implementing QOS in a mixed environment like this?
6 Replies 6
Marwan ALshawi
in case like ur
its better to mark the phones traffic manuly on the access switches in ur case on the 4500 switches
creat a policy map with calss map that match voip traffic like
permit udp any any range 16384 32767
and set it as dscp ef
and u need to find out each vender call signaling ports to match as well for advanced qos
with cisco ip phones the call signaling can be matched like
permit tcp any any range 2000 2002
for voip lets make simple policy to mark the traffic
ip access-list extended voice
class-map match-all ipphon
match access-group name voice
policy-map voip
class ipphon
set ip dscp 46
now lets sat u will apply it to the range interfaces on the 4500
interface range fa 0/1 -22
service-policy input voip
on global config mode do on 4500
qos
to enable qos
on all uplinks between switches u need to trust ur dscp marking in oreder to make sur this marking will be kept end to end till reach ur router and there u can make policies for priority
on each ulink
qos trust dscp
this is in brief if u want any more details just post here
good luck
if helpful Rate
Thanks...
Seems SNOM (320) Phone default uses:
Call signalling - SIP protocol, UDP 5060?
Calls use? RTP 10000 - 20000
TOS Default value 160 (0x28)
Anyone know how to enable QOS globally on a 3560?
---Mike
Ok, I've tested this config out on a 3560, any feedback would be greatly appreciated...
I have Snom phones and an Asterisk server.
Access-list with Snom SIP & RTP (Can I use the same ACL for both?):
ip access-list extended voip-traff
permit udp any any range 5060 5061
permit udp any any range 10000 20000
class-map named ipphone & match acl voip-traff:
class-map match-all ipphone
match access-group name voip-traff
Policy map named voip, match class-map iphone:
policy-map voip
class ipphone
set dscp cs5
set interfaces to police policy-map voip:
interface-range gi 0/1 - 48
enable qos globally:
mls qos
Does this look like a good config and will this actually do a rewrite of TOS?
---Mike
its ok but u need to add and change somthings
first add this command
mls qos map cos-dscp 0 8 16 24 32 46 48 56
it is help u if u use cos with dscp
now for ur class map make it match-any not match-all
class-map match-any ipphone
try to use dscp ef or 46
and the above config will mark all sip and rtp traffic with the marking u put
good luck
if helpful Rate
My Snom Phones default is DSCP 40 and I would like to stay with that if possible. Does this mean my qos map should be;
mls qos map cos-dscp 0 8 16 24 32 40 46 48
Many thanks!
as long as ur access switch is dscp aware and u will use dscp marking from the begining them u will not need this maping caommnd from cos to dscp
this one help when u trust or use cos on the access port then u go to dscp on the uplinks
and for ur case u can use the policy with set ip dscp
or as u stated above ur pohne is marking with dscp 40 and u happy with it
if u have only phone connected to the port without pc then u could use trust dscp on the port level
this way the port will use the dscp marked from the connected device this way u may dont need to creat policy for marking only
good luck
if helpful Rate
