QoS - output queues dropped.
martin.germano
Level 2
Level 2
Hi, i have a phone thats no working fine, it unregister all the time from the sip server.
The port connected to the phone has output queues dropped on queue 1. ¿That's normal? ¿What could be the cause that there drop packet?
Thanks!
I have this configuration for Qos on the switch port:
interface FastEthernet0/15
 switchport mode access
 switchport voice vlan 15
 priority-queue out
 mls qos trust cos
 spanning-tree portfast
sh mls qos int fa0/15 st
FastEthernet0/15 (All statistics are in packets)
  dscp: incoming
  0 -  4 :      184994            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0      2298420            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0      4806226            0        16934            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :     8134930            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0            0            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :         861            0            0            0            0
 45 - 49 :           0            0            0            5            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :      875001            0            0            0            0
  5 -  7 :     6544104            0            0
  cos: outgoing
  0 -  4 :     8781009            3            6            1            2
  5 -  7 :      275463            5        17983
  output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:      292615           0           0
 queue 1:     8562114       44049     5388502
 queue 2:           0           0           0
 queue 3:       17982           0      183824
  output queues dropped:
 queue 0:           0           0           0
 queue 1:        5349           0           0
 queue 2:           0           0           0
 queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
Terry Cheema
Martin,
Refer to this link you need to modify your buffers etc. :http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/116089-technote-switches-output-drops-qos-00.html
-Terry
Please rate all helpful posts
Terry Cheema
Martin,
-Terry
Thanks Terry, i'll try it.
No Worries, in case you get stuck please feel free to post back.
-Terry
Ok, i have a doubt about this: Why if QoS drop packets, why don't loses any ICMP packet at the same time?
in which QoS queue belong the ICMP packets?
Thanks.
