Cisco Community Designated VIP Class of 2020
467
Beginner
QRT & RTMT with CCM 5.1
I have searched through the QRT documentation for CCM 5.1 and nowhere can I find out it works.
I have placed the QRT softkey on a end users telephone. This user is using the QRT softkey correctly, and nowhere can I find the QRT trace on the CCM 5.1 server using RTMT 7.0.
The documentation says that QRT Viewer is part of the application, but I can't find it.
The only traces I find are CEF.txt traces, and those are far from the original QRT.txt traces that previous CCM version created.
Can anybody assist me?
Thank you,
Ben
1 ACCEPTED SOLUTION
Advocate
Re: QRT & RTMT with CCM 5.1
8 REPLIES 8
Advocate
Beginner
I'm having the same issue when looking for the QRT Event Viewer in 5.1. The guides direct you to a different system admin guide every time the QRT Event Viewer is mentioned?
Beginner
After running a few tests tonight I've found that you download any available qrt.xml files automatically when you collect CEF & CEF report traces within a specified time frame.
Beginner
Rob,
let me know this is correct
rtmt >> tools > trace > log central > collect files >> extended functions >> this is where I'm stuck
Beginner
You use the Real Time Monitoring tool for the QRT reports. QRT reports are automatically opened with the QRT Event Viewer with UCM 5.1.
Enthusiast
Hi, I'm having same problem. Can you give me more info please? I have got the softkey button,downloaded RTMT but cannot find any reports for QRT.
Highlighted
Beginner
R--
did you ever get this fixed?
Beginner
yes I did. A couple messages back is the answer regarding what traces you need to have turned on in order to see the QRT reports. The QRT Viewer opens automatically.
Content for Community-Ad
FusionCharts will render here
