Walkthrough Wednesdays
388
tkavithas87
Beginner
qsic trunk
  i am trying to  configuredqsic trunk between cme and panasonic pbx.but the controller is down.here is the show command.
cme#show controllers e1
E1 0/2/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (649 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 649 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
what could be the reason?
thanks
kavi
4 REPLIES 4
Leo Laohoo
VIP Community Legend
Duplicate post #1.
Chris Deren
Hall of Fame Master
Try different cable and crossover.
make CME trunk as master and panasonic as salve , waht you are using here , can you paste show isdn st here . here it alos shows loss of signal , check yr cabling aprt too
rgds
Amim
if this helps, please rate
hi,
and make sure you use all 30 channel of E1 ,as sometime it does not worked with fragmneted channel .
rgds
AMim
Content for Community-Ad
Spotlight Awards 2021
