06-24-2011 10:54 AM - edited 03-16-2019 05:37 AM
Hi there,
I just need to know if below MCS server can have both Communications Manager and Contact center express application active (co-resident) on the single server?
MCS7816I4-K9-CMD1 Unified CM 8.0 7816-I4 Appliance
CAB-ACU AC Power Cord (UK), C13, BS 1363, 2.5m
Included: CCX-80-CM-BUNDLE CCX 8.0 5 Seat CCX ENH CCM Bundle - AVAILABLE ONLY WITH CM
Included: CUCMS-EVAL-K9 CUCMS Monitoring Bundle Evaluation
Above is configured on Cisco Dynamic configuration tool, User license for Communications Manager BOQ is as below:
LIC-CUCM-USR-A 50
Unified Communications Manager Enhanced Single User-Under 1K
UCM-7816-80 1
CUCM 8.0 7816
Included: CCX-85-CMBUNDLE-K9 1
CCX 8.5 5 Seat CCX ENH CM Bundle - AVAILABLE ONLY FOR NEW CM
Included: CUCM-PAK 1
Include PAK Auto-expanding PAK for CUCM
Included: CUCM-USR 300
Include PAK Auto-expanding User for CUCM
Included: UCM-7816-80-KIT 1
CUCM 8.0 Media Kit
Included: UCM-7816-NODE 1
CUCM 7816 Node
Basically requirement is for small call center therefore I was thinking of using the bundle CCX available with CUCM and wanted both softwares to run on single MCS server for cost saving. contact center users required is only 5. IP communicator will be added in the above BOQ.
Best regards,
Faisal Qadri
06-24-2011 10:59 AM
That was possible in CCM 4.X , now it is not possible because both CCMand UCCX are linux and they can't run co-resident.
But if you work on it using VMWare i think it is possible , you have to check about that.
Amer
06-24-2011 11:05 AM
Hi Amer,
But why they are providing CCX bundle with CUCM then?
Faisal
06-24-2011 11:09 AM
Hi Faisal,
Amer is correct here (+5 "A")
The 5 seat bundle is included as a "Promotional" item and does save on
some significant Licensing costs. You do have to provide a seperate server
to run the UCCX on though.
Cheers!
Rob
06-24-2011 11:14 AM
Hi Rob,
Thanks for the clarification, it means I only need to add additional MCS server to the BOQ and it will fly.
Faisal
06-24-2011 11:29 AM
Yes , use the partnumber which ends with CCX , it will be a ready appliance for the UCCX, for the 5 enhanced , you can use the 7816 , you don't need more than that.
Amer
06-24-2011 11:43 PM
I have got below feed back regarding the server:
What do you suggest, what part numbers are required.
Faisal
06-25-2011 01:32 AM
Keefak faisal,
Listen,
I know this to be true a long time ago , this was before UCCX 8.0 becasue the UCCX used to be installed on cisco OS win2003 so at that time you need cisco OS which is cost around 3K , but now after UCCX 8.0 , it is linux based and it is no longer required.
Let me do a small research on the ordering for the free seats bundle.
Amer
06-26-2011 12:00 AM
Hello Faisal,
I don't think it is used any more , UCCX 8.0 and later is based on VOS platform , before UCCX 8.0 you needed cisco OS becasue it was based on windows 2003 , so all what you need is the sperate server , for the license you already going to get it when you buy the CUCM appliance , don't forget to order the UCCX server as appliance , it is better.
Amer
