214
Highlighted
Question about CIPC and Pickup Notification
Hi there!
I have a question about the componentes mentioned above.
Here I have a user which uses the CIPC over a VPN-Connection. He mentioned, that the audio notification from the Pickup-Group does not ring, when a call is "ready for pickup". I suppose, that the signalling is blocked on one of the million Firewalls between the VPN-Network and the VoIP-Core.
Now I want to know which port is used to send the audio notification. Then I can check it on the FWs.
Thanks for the Info!
DrMxxxxx
0 REPLIES 0
