Question about Cisco Unity Connection 8.5
Hello Friends,
I have a voicemail account which has 1 Primay extension, 1 Alternate extension my requirement here is i need to have 2 different password for both the extensions but still i should have a single voicemail box for both the extensions.
Is there a way where we can make it possible ?
Thanks.
Kulasekara Raja. K
rramirez
I think this will defeat the purpose of having an alternate extension in the same mailbox in order to use only one password to access. Best way will be to add another mailbox.
No, you cannot have 2 different passwords for one mailbox. If the idea is that multiple people share the mailbox they will both need to know what the passowrd is.
HTH,
Chris
