Beginner
question about pri config
Hello, i have a question about the following (this is 1 of 3 pri's on a router) :
controller T1 0/2/0
cablelength long 0db
pri-group timeslots 1-4,24 service mgcp
The pri is configured as "pri-group timeslots 1-4,24 service mgcp"
What does 1-4 mean ? it is only configured to use 4 channels, plus 24 for D channel? correct?
I believe it should be an entire PRI. i have a feeling there arent enough resources on the router
is there a way to check this ?
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
That's correct, that's the number of DS0s you're using, and we do not support you doing that, partial PRIs are only supported with H323, not with MGCP.
Use the sh tech and sh voice dsp to see DSP resource allocation
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
5 REPLIES 5
java
java
Highlighted
Beginner
Re: question about pri config
so this is in fact a partial pri..  i think it’s a full pri from the provider. we just don’t have enough dsp’s for it ?
this is what i get when i do show voice dsp :
sho voice dsp
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
SP2600 001 01 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  14    0  28288/28978
SP2600 001 02 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  15    0  15686/16097
SP2600 001 03 voice         31.1.0 busy  idle      0  0 0/0/0:23  10    0     955/5455
SP2600 001 04 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  22    0  65727/67262
SP2600 001 05 g711ulaw      31.1.0 busy  idle      0  0 0/0/1:23  01    0    9747/9887
SP2600 001 07 g711ulaw      31.1.0 busy  idle      0  0 0/0/1:23  02    0    7622/7567
SP2600 001 08 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  20    0    7010/7217
SP2600 001 09 voice         31.1.0 busy  idle      0  0 0/0/1:23  03    0       192/93
SP2600 001 10 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  19    0 125998/12906
        7
SP2600 001 11 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  18    0 127743/13092
        7
SP2600 001 12 g711ulaw      31.1.0 busy  idle      0  0 0/0/1:23  04    0  17706/17893
SP2600 001 13 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  16    0    1252/1307
SP2600 001 14 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  11    0  81767/83843
SP2600 008 01 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  17    0    5813/5979
SP2600 009 01 g711ulaw      31.1.0 busy  idle      0  0 0/0/1:23  05    0    3300/3302
SP2600 009 02 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  21    0  33327/34116
SP2600 009 03 g711ulaw      31.1.0 busy  idle      0  0 0/0/0:23  12    0       726/59
                           *DSP SIGNALING CHANNELS*
SP2600 001 01 {flex}        31.1.0 alloc idle      0  0 0/1/0     02    0         37/0
SP2600 001 02 {flex}        31.1.0 alloc idle      0  0 0/1/1     06    0         37/0
SP2600 001 03 {flex}        31.1.0 alloc idle      0  0 0/1/2     10    0         20/0
SP2600 001 04 {flex}        31.1.0 alloc idle      0  0 0/1/3     14    0         20/0
------------------------END OF FLEX VOICE CARD 0 ----------------------
and this is part of show tech :
------------------ show diag ------------------
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 11 ports
        Port adapter is analyzed
        Port adapter insertion time 7w6d ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        :
        Hardware Revision        : 1.0
        Part Number              : 73-11835-03
        Top Assy. Part Number    : 800-30794-01
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V01
        CLEI Code                : COMGL00ARA
        Processor type           : C2
        Chassis Serial Number    :
        Chassis MAC Address      :
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 34 31 30 35 30 47 54 40
          0x10: 06 16 41 01 00 82 49 2E 3B 03 C0 46 03 20 00 78
          0x20: 4A 01 42 42 30 88 00 00 00 00 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 31 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4F 4D 47 4C 30 30 41 52
          0x50: 41 09 C2 C2 8B 46 54 58 31 34 31 37 41 48 44 47
          0x60: C3 06 68 EF BD B7 85 A0 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-01
        PCB Serial Number        : DCA1408K08F
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : B0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 01 88 00 00 00
          0x10: 00 C1 8B 44 43 41 31 34 30 38 4B 30 38 46 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 31 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F3 18 3B 02 F0 19 D9 03 E8 1B 76
          0x60: 04 E2 1C 49 05 D9 1D 1B 06 D8 1D ED 07 CF 1E BF
          0x70: 08 CE 1F 40 09 C2 1F B8 0A B8 20 34 0B B7 20 B0
          0x80: 0D AF 21 0C 0F 9F 21 67 11 91 21 94 13 87 21 C0
          0x90: 17 6E 21 DB 1B 57 21 EA 1F 3F 21 E2 23 28 21 D4
          0xA0: 27 0A 21 CD 42 42 30 FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11577-03
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        :
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-32
          0x00: 04 FF 40 05 D9 41 01 00 82 49 2D 39 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 34 31 32
          0x20: 35 38 58 4E 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 33 32 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        128-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11810-03
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        :
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-128
          0x00: 04 FF 40 05 DC 41 01 00 82 49 2E 22 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 34 31 33
          0x20: 33 46 46 33 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 32 38 20 20 20 20 20 20
        WIC Slot 0:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        :
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 34 31 35 32 4B 4B 57 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
        WIC Slot 1:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-04
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        :
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        Version Identifier       : V03
        CLEI Code                : CNUIAXJAAB
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 04
          0x10: 42 42 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 34 31 34 33 4A 44 55 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 33 20
          0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 42 FF FF FF FF
        WIC Slot 2:
        Board Revision           : B0
        Fab Version              : 04
        PCB Serial Number        :
        RMA History              : 00
          0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 32 31 36 35 4E 44 57 03 00 81 00 00 00 00 04 00
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
------------------ show inventory ------------------
NAME: "CISCO2921/K9 chassis", DESCR: "CISCO2921/K9 chassis"
PID: CISCO2921/K9      , VID: V01 , SN:
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN:
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN:
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 2", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128         , VID: V01 , SN:
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V01 , SN:
You've more than enough DSP resources to configure that full PRI, you got a 32 and a 128 PVDM3
java
java
Beginner
hmm okay, thanks so much Jaime, this is an existing config, so i am not sure why it was configured this way.
How should I go about making the change from 1-4 to 1-24 ?
Remove the existing config or is it possible to change the pri-group timeslots from 1-4 to 1-24?
This is a failover pri
You need to remove the current config as it's currently active, once you remove it, reconfigure it.
You can search CCO for MGCP config and you'll get plenty of examples on how it should look like.
java
java
Content for Community-Ad
August's Community Spotlight Awards
