question about the output of debug isdn q931
ciscoroyzhang
Beginner
Beginner
                   HI there,  I have a quick question. when use debug on the voice gateway with above command,  it will display the called number. My understanding is that this called number is sent from CUCM and this number will match one of the dial peer in router and then go throught the voice translation profile, then be sent out to ISDN, am I correct?   if so, which command can show me the exact number after digits manipulation on router sent to the Telco?
Debug voip ccapi inout..if you are using h323 gateway and
debug ccsip messages, if you sre using a sip trunk/gateway
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
IN addition you can also use:
debug voice dialpeer
and
debug voice translation
to see exactly which dial peer is matching after which digit and what is being translated to what.
Chris
For an outbound call (from CUCM to ISDN) that would be debug isdn q931 as you are using already. That shows the actual setup message sent out on the ISDN after any manipulation.
Obviously for inbound calls, it shows what you receive from the PSTN before any manipulation happens.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Recognize Your Peers
