11-07-2012 12:00 AM - edited 03-16-2019 02:03 PM
I have a quick question on AAR. In our country DoT regulation says IP & PSTN Calls should not mix. In AAR, if i make a call to branch office, it will go in IP network, if i want to conference the call with a PSTN number, can the IP call get converted to a PSTN Call???
Thank you
PC
11-07-2012 02:10 AM
Not ASFAIK. AAR is used by CUCM when you have CAC that report that not enough bandwidth is available to complete the call as a VoIP call, that would trigger AAR to reroute the call to PSTN.
Please remember to rate helpful responses and identify helpful or correct answers.
11-07-2012 05:43 AM
I think you nees to look into geolocation. Also how you interpret your legislation if ip and pstn call should never mix conferencing would be ilegal, but I dont remember a country that prohibits this.
The restriction ia more like a PSTN should not do toll bypass through your corp IP backbone. Which is why we created geolocations and logical partions (weird feature by the way)
