Question on configuring E1 Circuit
ciscoroyzhang
Hi there,   I have configured the E1 link as following
    Controller E1 0/0/0
     pri-group timeslots 1-10
and check the new S0/3/0:15 interface, it shows:
    interface Serial0/0/0:15
     isdn switch-type primary-net5
     isdn incoming-voice voice
question:  do I need issue the following command, since without them it still works fine?
     isdn bchan-number-order ascending
     isdn outgoing display-ie
Roy
6 Replies 6
ronpatel
Level 8
Level 8
Hi Roy,
Without the above two commands also the PRi link will work. These are not mandatory configuration.
Ronak Patel
Rate Helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak. thanks for the reply.   about the    isdn bchan-number-order ascending  I was told that by default the client site ISDN channel will be in desending mode and if it is in fructional, then we have to change it to acending so the call will not start to use the channel 30 which is not availble in isdn 10. but seem to me this is not corrrect.  thanks Roy
Hi Roy
That is one solution to a fractional PRI - I have a lot of customers here in the UK using the same configuration, though it's not exactly what Cisco recommend it seems to work fine.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
The limitation only exists for MGCP. For all normal gateway-based protocols Cisco did not ever made statements on the matter, and supported any number of timeslots since day 1 (when voice PRI did not even existed).
Hi Paolo
Erm.. yes. My mistake, I was in MGCP mode and was wrong even with regards to MGCP! It would be the channel selection order in CUCM that would be changed, as the command on the gateway would only affect H.323
oops.
Aaron
Router will place always outgoing calls starting from the highest free channel, so nce you configure timeslots 1-10 as in the example above, that will be channel 10.
Consequently, the default of 'descending' works fine and does not need to be changed.
